[Solved] Unkown error on 4.2.2 Linux
I had 4.2.1 working fine, but 4.2.2 gives an unknown error if i try to login. Is there any fix for this?
Here is the log,
Jun 04, 2022 23:24:05.577 [0xeabfb640] DEBUG - Networking: Completed request 6: (POST https://plex.tv/api/v2/users/signin?login=blahblah&password=blahblah) with code -59 (have 0 bytes) in 286 ms.
Jun 04, 2022 23:24:10.077 [Javascript] INFO - Memory usage: 26.3MB
Jun 04, 2022 23:24:10.079 [Javascript] INFO - Companion: attempting to connect to pubsub, started true connected false
Jun 04, 2022 23:24:10.079 [0xf7b81a40] DEBUG - Networking: Create request 7: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>).
Jun 04, 2022 23:24:10.538 [0xeabfb640] DEBUG - Networking: Completed request 7: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>) with code -59 (have 0 bytes) in 459 ms.
Jun 04, 2022 23:24:10.539 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:24:21.616 [Javascript] INFO - Discovery: Fetching hubs for library null server null refreshing from cloud false.
Jun 04, 2022 23:24:25.079 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:24:38.243 [Javascript] INFO - Discovery: Fetching hubs for library null server null refreshing from cloud false.
Jun 04, 2022 23:24:40.078 [Javascript] INFO - Memory usage: 26.3MB
Jun 04, 2022 23:24:40.080 [Javascript] INFO - Companion: attempting to connect to pubsub, started true connected false
Jun 04, 2022 23:24:40.080 [0xf7b81a40] DEBUG - Networking: Create request 8: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>).
Jun 04, 2022 23:24:40.122 [0xeabfb640] DEBUG - Networking: Completed request 8: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>) with code -59 (have 0 bytes) in 41 ms.
Jun 04, 2022 23:24:40.122 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:24:42.473 [0xf7b81a40] DEBUG - Networking: Create request 9: (POST https://plex.tv/api/v2/users/signin?login=blahblah&password=blahblah).
Jun 04, 2022 23:24:42.628 [0xeabfb640] DEBUG - Networking: Completed request 9: (POST https://plex.tv/api/v2/users/signin?login=blahblah&password=blahblah) with code -59 (have 0 bytes) in 154 ms.
Jun 04, 2022 23:24:45.628 [Javascript] INFO - Auth: Requesting PIN.
Jun 04, 2022 23:24:45.630 [0xf7b81a40] DEBUG - Networking: Create request 10: (POST https://plex.tv/api/v2/pins?strong=true).
Jun 04, 2022 23:24:45.783 [0xeabfb640] DEBUG - Networking: Completed request 10: (POST https://plex.tv/api/v2/pins?strong=true) with code -59 (have 0 bytes) in 153 ms.
Jun 04, 2022 23:24:45.784 [Javascript] ERROR - Auth: Could not get PIN HTTP status -59
Jun 04, 2022 23:24:55.080 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:25:10.078 [Javascript] INFO - Memory usage: 26.3MB
Jun 04, 2022 23:25:10.081 [Javascript] INFO - Companion: attempting to connect to pubsub, started true connected false
Jun 04, 2022 23:25:10.081 [0xf7b81a40] DEBUG - Networking: Create request 11: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>).
Jun 04, 2022 23:25:10.145 [0xeabfb640] DEBUG - Networking: Completed request 11: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>) with code -59 (have 0 bytes) in 63 ms.
Jun 04, 2022 23:25:10.145 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:25:25.081 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:25:40.078 [Javascript] INFO - Memory usage: 26.3MB
Jun 04, 2022 23:25:40.081 [Javascript] INFO - Companion: attempting to connect to pubsub, started true connected false
Jun 04, 2022 23:25:40.082 [0xf7b81a40] DEBUG - Networking: Create request 12: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>).
Jun 04, 2022 23:25:40.125 [0xeabfb640] DEBUG - Networking: Completed request 12: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>) with code -59 (have 0 bytes) in 43 ms.
Jun 04, 2022 23:25:40.125 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:25:55.082 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:26:10.078 [Javascript] INFO - Memory usage: 26.3MB
Jun 04, 2022 23:26:10.082 [Javascript] INFO - Companion: attempting to connect to pubsub, started true connected false
Jun 04, 2022 23:26:10.082 [0xf7b81a40] DEBUG - Networking: Create request 13: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>).
Jun 04, 2022 23:26:10.327 [0xeabfb640] DEBUG - Networking: Completed request 13: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>) with code -59 (have 0 bytes) in 244 ms.
Jun 04, 2022 23:26:10.327 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:26:17.974 [Javascript] INFO - Discovery: Fetching hubs for library null server null refreshing from cloud false.
Jun 04, 2022 23:26:25.082 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
Jun 04, 2022 23:26:40.078 [Javascript] INFO - Memory usage: 26.3MB
Jun 04, 2022 23:26:40.083 [Javascript] INFO - Companion: attempting to connect to pubsub, started true connected false
Jun 04, 2022 23:26:40.083 [0xf7b81a40] DEBUG - Networking: Create request 14: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>).
Jun 04, 2022 23:26:40.310 [0xeabfb640] DEBUG - Networking: Completed request 14: (GET https://pubsub.plex.tv/sub/eventsource/null/null?X-Plex-Token=<token>) with code -59 (have 0 bytes) in 226 ms.
Jun 04, 2022 23:26:40.310 [Javascript] INFO - PubSub: Connection broken to plex.tv, reconnecting.
If i go to plex.tv in the browser, it works perfectly.
There’s another thread about the dreaded error 59 (CURLE_SSL_CIPHER). I’m honestly not sure why it’s starting to happen all of a sudden.
I had a look at that thread. Looks like all of us are Arch users.
@elan Is this something planned to be done about this or will the ArchLinux users going to be left out?
PS: My suggestion would be to spin up an ArchLinux VM and give this a go.
Nevermind, this fixed he issue.
