Hello,
I am a new user (installed Plex for the first time over the weekend) but already I ran into a big problem that doesn't seem to have a solution.
I used Plex on Saturday to add video files to my Movies library using the Plex web interface. That process worked perfectly and I then purchased the app for my iPad. At this time, my added MOV and MP4 video files continue to play and work perfectly using Plex. I was really impressed with the AirPlay feature so that I could "beam" my iPad video to my Apple TV 3 box. I also installed the Roku app, and it works fine.
The next day (Sunday), I tried to add an MKV file to a Plex library--and the file does not appear when I go to Edit LIbrary, access the Folders tab, click Add Folder, and point to a folder on my system that contains the MKV file (I tried placing it in many different folders, to no avail). When I say that the file doesn't "appear", I mean that the file name doesn't show when I drill down into the folder that contains the MKV file using the Add Folder dialog. (When I added MP4 files on Saturday, they show in the Add Folder dialog, so I figured that MKV files should also show if they're present and if I'm correct that they're supported by Plex). If I ignore the fact that the MKV file isn't listed and simply add the folder that contains it then the MKV doesn't magically appear when I go back to the home page and click the Movies library. I tried all sorts of refreshes--the MKV file that's sitting in the added folder simply isn't getting added to the library I added it to.
I have read numerous posts of this issue with all sorts of suggestions--some that seem like pure voodoo (such as using lowercase s01e01 instead of S01E01)--but none of those suggestions has worked.
So I have a few questions:
1) Would someone please confirm that Plex has the ability to add .MKV files to a library and then make then streamable using a Plex client? In fact, can you please point me to a page or list that shows all compatible video-format extensions the work with Plex?
2) Are there certain types of MKV files that are excluded (such as those above 1GB or those with a certain type of metadata)?
3) In Windows, I have a folder called Movies under my logged-on user's Documents folder (I am an admin on the Windows box). I placed a single MKV file into that Movies folder and I just want to add that to a library called Movies.
I have tried naming the MKV file using each of the following--to no avail:
test.mkv
test (2014).mkv
test S01E01.mkv
test S01E01 (2014).mkv
testS01E01.mkv
testS01E01(2014).mkv
testS01E01 (2014).mkv
test S01E01(2014).mkv
All forums member seem to suggest that the file could not possibly be named correctly and have suggested names such as those in my list.
Am I doing something wrong?
To make things interesting, I tried a test: I copied an MP4 file that I have already successfully added to a Plex library called Tutorials, so I know that this MP4 file works with Plex and can be added to a library. However, when I copy the MP4 file to my documents\movies folder (where the MKV file is located), it also doesn't show when I try to add it to a library using the Plex Edit Library process. Why would I not be able to see a file that's named exactly the same way when I move it from one folder on my system to another?
4) I have restarted the Plex server, restarted Windows, uninstalled and reinstalled the Plex server, cleared its various caches--to no avail.
I don't really understand what the Plex Media Server is doing when a user clicks the Add Folder button in the Edit Library feature, but shouldn't it be rather straightforward? Should the process look at the file system and enumerate the files that are there and simply show them (or throw an error as to why it can't do this)?
I have a small but academic library of MKV files and I was quite sure that a former colleague of mine said that MKV plays well with Plex. I purchased the Plex app with the intention of viewing MKV files. So any help anyone can offer would be appreciated.
