Some 4k HDR stop working Samsung QLED
Some movies works but most stop working after a few minutes on my modern Samsung QLED 4k TV’s.
However, the same movies work flawlessly on my Windows computer. I am currently using the latest Plex version within a Docker container and have a 1 Gbps Ethernet connection to the TVs.
My Samsung’s should support HDR10+, HLG10, Quantum HDR, Quantom 4K Lite.
One movie that works;
4K DoVi/HDR10 (HEVC Main 10)
Bitrate: 13438 kbps
One that dosnt work:
Bitrate: 25.2 Mbps
Is it simply the bitrate that is the issue? or do you have any insights into why this happening?
This isn’t a solution, but I’m encountering a similar problem. When I transfer a movie that doesn’t function on my Plex-enabled Samsung device to a USB stick and insert it into the same Samsung TV, the movie plays without any issues. This suggests that the problem may be related to my network-attached storage (NAS), Plex server, LAN setup, or the Plex app itself, rather than the video format, since the movie plays smoothly on the TV.
the tizen client is just a disaster, dont overthink it, its not your fault.
