I just started with the plex server on my raspberry pi. Everything was going good but suddenly I noticed that some of my files aren’t visible specially web series
Movies works fine but some times they tend to change the metadata which can be fixed but refixing match but some of the contents aren’t visible
For eg I just droped some web series on the plex server and some of the episodes arent visible while some are I tired rescanning file library again and again also renamed the file names as per serial order but same result
What should I do
Also there isn’t any option to do most work on the smartphone app even though It requires a one time purchase
