Some files won't run smoothly. Framerate?
Hello Guys,
Sorry for reposting, but in the plex synology thread is no response.
first I have to say great work bwynants!! Great job! :-)
I did a quick test in my environment. Two critical 1080p's are working fine. But some of my 720p series are having trouble. Sound is really smoothly, but video isn't good. I wouldn't say that is stuttering, it's more not running smoothly.
Here are some infos about the used files:
This one is bad:
General
Unique ID                                : xxxxxxxxxxx
Complete name                            : \\DISKSTATION\video est.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 1.47 GiB
Duration                                 : 41mn 19s
Overall bit rate                         : 5 102 Kbps
Movie name                               : Test
Encoded date                             : UTC 2012-11-25 16:10:07
Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L3.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 2 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 41mn 19s
Bit rate                                 : 4 104 Kbps
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 25.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.178
Stream size                              : 1.18 GiB (80%)
Default                                  : Yes
Forced                                   : No
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Duration                                 : 41mn 19s
Bit rate mode                            : Constant
Bit rate                                 : 448 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 132 MiB (9%)
Language                                 : German
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 41mn 19s
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Language                                 : English
Default                                  : No
Forced                                   : No
This one is good:
General
Complete name                            : \\DISKSTATION\video\Test2.mkv
Format                                   : Matroska
File size                                : 888 MiB
Duration                                 : 25mn 35s
Overall bit rate                         : 4 854 Kbps
Encoded date                             : UTC 2012-01-25 13:10:20
Writing application                      : mkvmerge v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
Writing library                          : libebml v1.0.0 + libmatroska v1.0.0
Video
Format                                   : AVC
Format settings, GOP                     : N=1
Duration                                 : 25mn 35s
Bit rate                                 : 4 182 Kbps
Height                                   : 720 pixels
Frame rate                               : 23.976 fps
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.189
Stream size                              : 765 MiB (86%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #1
Format                                   : AC-3
Format profile                           : Dolby Digital
Codec ID                                 : A_AC3
Duration                                 : 25mn 35s
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Bit depth                                : 16 bits
Stream size                              : 35.1 MiB (4%)
Language                                 : German
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 25mn 35s
Bit rate                                 : 384 Kbps
Bit depth                                : 16 bits
Stream size                              : 70.3 MiB (8%)
Language                                 : English
Default                                  : No
Forced                                   : No
Guys do you have idea about this?
Is there an issue regarding video framerate 25fps and 23,976fps?
BTW: ATV3 with latest iOS, PMS 0.9.7.28, DSM DSM 4.2-3202
The ATV does not support native 24FPS but should still play it.
What happens if you try and play both using the desktop or even more telling the iOS client?
With iOS I don't know exactly, I will check this later. With PLEX for Samsung it's working fine, no problems with video (framerate).
The problem file is coded with a framerate of 25fps. 24fps (23,9xxfps) is working fine on ATV3.
Try remuxing to MP4 and check it via iTunes/Homesharing, too. How does it behave then?
I had the same problem but fixed it by setting the output of the Apple TV to 1080p@60hz and turning on TruMotion (Probably called different on other TV's).
It worked for me on my LG TV, perhaps it works on yours too.
I experienced the same problem. I have this on my Apple TV 3 (plexconnect) and also on my Mac-Mini. When i watch the movie via my browser it plays smoothly. This issue occurs when something moves and the camera is moving.
Is there no satisfying solution? Again with PLEX for Samsung it's working fine....
Well a number of questions were asked of you but you did not provide any answers......
23,xx fps are no problem. 25 fps is making trouble.
With iOS client and files with 25fps there are no problems. It is playing very well. Using webclient of PLEX server is also perfect.
I tried different settings and it was a little bit better, but not playing well. It would not be an option to change settings again and again before playing a video file.
I don't understand why PlexConnect and RasPlex is making trouble with 25fps and iOS, PLEX for SamsungTV not. Could anybody explain that?
So you tested with exactly the same file on the Plex iOS client and PlexConnect (it is not clear from your reply if you did)?
Please provide a sample of one of the problem files if the answer to the above is yes.
I don't know if it is exactly the same file from my first post. It was a file with 25fps.
You are assuming that 25fps is the problem.
Test using the same file and see what happens, if you get the same result then post a sample of it and link to it here.
