Some Media Not Appearing in Player Library
Apparently on any devices I have with the “new” UI (confirmed on iPhone and iPad, both beta and release), at least one movie I have doesn’t appear (“Frozen: A Musical Spectacular”). It does show up if you search for it, and it also appears as expected on the web interface and on Apple TV running the “old” UI.
I’m not sure if any other movies are missing, I have far too many to go through them all, this is just the first I’ve noticed.
Server Version#: 1.41.8.9834
Player Version#: Multiple
Please look at the plex media info XML of that particular item.
What appears in the XML property named guid="... (all lower case!) ?
What has been set as the metadata agent of the library where this item is located?
The guid is “plex://movie/5fa96858f709b8002db179c2”.
The library’s metadata agent is “Plex Movie”.
Did you add this movie into a collection, perhaps?
Or did you attach an {Edition} tag to it?
Not in a collection, and it has no edition set. And like I said, it appears normally on the web interface and the “old” Apple TV UI.
Does it lack an age rating, perhaps?
Is “Allow matching to explicit content” enabled in the properties of this library?
It doesn’t have a “content rating” set. “Allow matching to explicit content” is not set on the library.
I tried setting the content rating to “G” and also tried enabling match explicit content, neither made any difference.
Disable that if you don’t need it. When activated, it would rather restrict even more features than help with your issue.
I turned it back off after testing. Just wanted to see if it made any change.
Btw. I tried to find your movie, but couldn’t see it either on IMDb nor on https://watch.plex.tv
The only hit I got is on TMDB Frozen: A Musical Spectacular (2020) — The Movie Database (TMDB)
It’s on TMDB, and I’m assuming that’s what it pulled from since all the info matches. Frozen: A Musical Spectacular (2020) — The Movie Database (TMDB)
And this movie is missing when you browse the regular Library view?
Or is it only missing in the Discovery page?
It’s been in my library a long time, so it doesn’t appear in Discovery at this point. It shows fine in searches, and in the library of devices with the old UI. The only place I know for sure it’s missing is the library view of devices with the new UI.
I found another movie that’s missing in the “new” UI: Strangers on a Train
