Some media set to audio: none video: none
Hello,
For some reason some video’s are not playable in the webversion of Plex. In the webversion you can even see that the video and audio is set to none!
When I try to play the video I will get this error message:
But when I use Plex on my Android TV or my Android app on my phone, the video plays without any problems!
Nobody!!?
Is that the same video file on the same server or different servers? Which versions of PMS (on what platform) and player apps (e.g. hosted web app vs. bundled web app)?
Also… what information about the media do you see in > Get Info > View XML?
Or do you experience this behavior on Plex‘s own video-on-demand service?
I have my own media on an UNAS Pro from Unifi. I use the plex media server on a Windows 11 64bits machine. I’m running Version 1.41.2.9200 video is only playable on the Android TV app or all the others apps, but not on the web app.
I don’t use on-demand.
But VLC Player on my computer couldn’t play the same media either.
The following I get from view XML: see attachment
MediaContainer size=1 allowSync=1 i.txt (6.3 KB)
So still no help? Why doesn’t plex has a proper support departement for paying users?
Plex doesn’t recognize any media tracks in your file.
There should be Stream elements inside the Part, but it’s empty (no video, no audio, no subtitles).
You’ve said the file isn’t playing in VLC either – so my guess is you’re dealing with a bad file.
But it’s weird because you also said, it’s working fine on the Android / Android TV Plex clients.
Can you try to trigger Analyze for the episode in question and check if that’s updating the details. If it doesn’t – can you pass the file through the MediaInfo app to see if that can find anything else?
https://support.plex.tv/articles/201998867-investigate-media-information-and-formats/
Analyzing takes for every, I download media info, nothing out of the ordinary.
What do you mean by this?
Would you mind sharing your server logs from when you were analyzing the file?
To be honest, it still running since you asked me to do it, it never completed.
Here you can see the same video on my Google TV in the Plex App.
The only thing that is none, is the subtitle, but that of no concern.
And here it plays without any issue on my TV:
But in the webbrowser:
I provide the logs, but I can’t remember where i start the analyze
Plex Media Server Logs_2024-12-17_10-32-33.zip (4.0 MB)
According to those logs, you’ve run a lot of parallel activities. The server was busy detecting intros / scanning your library. In between you triggered the analysis of individual episodes. The analysis seems to have finished within 1-2 seconds – maybe the icon got stuck because the library was being analyzed and the item was still in queue to be analyzed.
The logs are also showing that the analysis fails due to some issue with the file.
That doesn’t have to mean the file is entirely corrupted – it could simply be that some parts of the container are corrupted while the tracks themselves are fine. It appears, the Android app is happily streaming on with or without valid analysis while the web app depends on the analysis data for certain playback decisions, hence failing to play.
You could try to run the file in question through MKVToolNix (or another remuxer). This should copy the tracks into a new container – you could check if the analysis works ok if you replace the original file with the remuxed one.
Yep running it with MKVToolNix work, thanks!
