This may be related to this issue: https://forums.plex.tv/discussion/311910/an-error-occured-while-attempting-to-play-this-video-amazon-fire-tv-media-player
I’ve recently started adding video captured from my security cameras to my plex library. I can play this videos fine through the web UI, but they won’t play via my android app - I get the “An error occurred while attempting to play this video” message. As far as I can tell the plex server doesn’t even get a request from the client when hitting play; the error pops up almost immediately.
Here are details of one of the videos from ffprobe
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'front_2018-04-07_00-16-44_161.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf56.40.101
Duration: 00:00:06.66, start: 0.000000, bitrate: 2089 kb/s
Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 1280x960, 2087 kb/s, 14.27 fps, 29.58 tbr, 14336 tbn, 28 tbc (default)
Metadata:
handler_name : VideoHandler
The only real difference I can tell between this videos and others that do play is that these are no audio streams.
As I said these videos play fine via the web-ui (which includes using the web ui on the android device) - it is just the android client that has a problem. The videos also play fine on smart TV via the TV app (LG webOS).
