Server Version#: 1.18.2.2058
Chromecast2
Windows Server
Cant seem to figure out why some movies tend to stutter through chromecast whilst other with higher res/bitrate/depth/file size/framerates stream perfectly. I tend to stick with H.264 which ive had good luck with so far. Files in the past ive muxed, removed image subs/excessive audio codecs but theres something im overlooking. Another thing ive noticed is that when i cast through chromecast according to my dashboard it streams at 10gbps. I then replay that same file through kodi/android/http it’ll drop to around 8mbps.
Anyone have any idea how to overcome this issue?
Thanks!
