When I attempt to control another player using plexamp the interface goes blank
Somewhat expected, because visualizers only work locally; we’ll make it jump back to album art/soundprint when remotely connected so that it doesn’t go blank. We’ve made a fix in 1.0.2 for this to work a bit more cleanly.
I think the Retrospect visualizer might be broken as it doesn’t seem to do anything.
This was some sort of weird GLSL issue, fixed in 1.0.2.
maybe have some kind of loading indicator when metadata is coming in
Agreed, we’re in need of loading indicators, error dialogs, that sort of thing
it would be really nice to have the option to have plexamp show on all virtual desktops
We’ve added this for you in 1.0.2.
enabling multiple libraries at once would be
Search works across multiple libraries; not sure how you would envision it working specifically?
Hypothetically all the discovery sections would pull info from all the libraries you have enabled as sources, and both radios would do the same.
I see, I figured itd be possible because the plex web client does it. the /hubs request it does returns a home.music.recent hub that contains newly added albums from both of my music libraries.
