Server Version#: 4.108.0
Friends. Help me, please. I installed a new plex server and it started scanning the library. In some series and movies posters are not loaded. When I click on the pencil to correct the data, then in the group “poster” I see several different posters. I click on any of them, but it is in the general list of movies and series nothing changes. How can I solve the problem? Installed a new server on a similar problem on the old server.
Can you please grab the server logs (settings - server - troubleshooting (lower left) - Download Logs) ?
It will give you a ZIP file
Please attach it here.
I’ll look to see if there are any obvious errors happening.
After that, I’ll ask you (you can provide now if you wish), a few samples of your filenames exactly as you have them.
(Two servers are unlikely to have the same problem. Two servers, sharing the same media files, it’s likely a problem with naming , structures, or permissions )
Plex Media Server Logs_2023-08-20_01-45-08.zip (7.3 MB)
I’m attaching a zip log
From.S02/From.S02E01.1080p.rus.LostFilm.TV.mkv
If I understand you correctly, it looks like this is the name of the folder and the file itself. As far as I can see, all information except the poster is loaded, that is, there are actors, description of the series and soundtrack is played
Thanks for the ZIP. There are no file system / permission errors.
I think your problem, knowing it happens to two servers, AND what I see in your logs, – is structure and naming.
This is incorrect.
Plex standard for the series “From” would be:
From/
Season 02/
From - S02E01 - optional_title_here.ext
As example, Here is series “The Rookie”
[chuck@lizum tv2.1999]$ cd *Rookie*
[chuck@lizum The Rookie.2000]$ ls -la
total 24
drwxrwxr-x 7 chuck chuck 115 Nov 18 2022 ./
drwxrwxr-x 53 chuck chuck 4096 Aug 1 00:19 ../
drwxrwxr-x 2 chuck chuck 4096 Nov 18 2022 Season 01/
drwxrwxr-x 2 chuck chuck 4096 Nov 18 2022 Season 02/
drwxrwxr-x 2 chuck chuck 4096 Nov 18 2022 Season 03/
drwxrwxr-x 2 chuck chuck 4096 Nov 18 2022 Season 04/
drwxrwxr-x 2 chuck chuck 4096 May 3 03:26 Season 05/
[chuck@lizum The Rookie.2001]$ cd *01
[chuck@lizum Season 01.2002]$ ls -la
total 50250348
drwxrwxr-x 2 chuck chuck 4096 Nov 18 2022 ./
drwxrwxr-x 7 chuck chuck 115 Nov 18 2022 ../
-rw-r--r-- 1 chuck chuck 2473206938 Nov 18 2022 The Rookie - S01E01 - Pilot.mkv
-rw-r--r-- 1 chuck chuck 2751427193 Nov 18 2022 The Rookie - S01E02 - Crash Course.mkv
-rw-r--r-- 1 chuck chuck 2677675073 Nov 18 2022 The Rookie - S01E03 - The Good, the Bad and the Ugly.mkv
-rw-r--r-- 1 chuck chuck 2139998598 Nov 18 2022 The Rookie - S01E04 - The Switch.mkv
-rw-r--r-- 1 chuck chuck 2201304834 Nov 18 2022 The Rookie - S01E05 - The Roundup.mkv
-rw-r--r-- 1 chuck chuck 2484732679 Nov 18 2022 The Rookie - S01E06 - The Hawke.mkv
-rw-r--r-- 1 chuck chuck 2270384948 Nov 18 2022 The Rookie - S01E07 - The Ride Along.mkv
-rw-r--r-- 1 chuck chuck 851251831 Nov 18 2022 The Rookie - S01E08 - Time of Death.mkv
-rw-r--r-- 1 chuck chuck 2060020308 Nov 18 2022 The Rookie - S01E09 - Standoff.mkv
-rw-r--r-- 1 chuck chuck 2893428820 Nov 18 2022 The Rookie - S01E10 - Flesh and Blood.mkv
-rw-r--r-- 1 chuck chuck 3093071696 Nov 18 2022 The Rookie - S01E11 - Redwood.mkv
-rw-r--r-- 1 chuck chuck 2823083068 Nov 18 2022 The Rookie - S01E12 - Heartbreak.mkv
-rw-r--r-- 1 chuck chuck 2971250189 Nov 18 2022 The Rookie - S01E13 - Caught Stealing.mkv
-rw-r--r-- 1 chuck chuck 2966384740 Nov 18 2022 The Rookie - S01E14 - Plain Clothes Day.mkv
-rw-r--r-- 1 chuck chuck 2751360540 Nov 18 2022 The Rookie - S01E15 - Manhunt.mkv
-rw-r--r-- 1 chuck chuck 2938215989 Nov 18 2022 The Rookie - S01E16 - Greenlight.mkv
-rw-r--r-- 1 chuck chuck 2756170993 Nov 18 2022 The Rookie - S01E17 - The Shake Up.mkv
-rw-r--r-- 1 chuck chuck 2747056944 Nov 18 2022 The Rookie - S01E18 - Homefront.mkv
-rw-r--r-- 1 chuck chuck 2835773940 Nov 18 2022 The Rookie - S01E19 - The Checklist.mkv
-rw-r--r-- 1 chuck chuck 2770508156 Nov 18 2022 The Rookie - S01E20 - Free Fall.mkv
[chuck@lizum Season 01.2003]$
Here –
Aug 20, 2023 01:17:48.587 [140600764439352] DEBUG - Scanner: Processing directory /media/bigmedia/film/feature/my/The Da Vinci Code + Angels & Demons [Extended Cut] (2006-2009) [1080p] BDRip (parent: yes)
Aug 20, 2023 01:17:48.588 [140600764439352] DEBUG - Skipping over directory 'The Da Vinci Code + Angels & Demons [Extended Cut] (2006-2009) [1080p] BDRip', as nothing has changed; removing 2 media items from map.
You must be very careful doing this. Recommendation is to NOT do it because the scanner will often group them together in something you don’t expect.
I have each movie separated
[chuck@lizum ~.1998]$ movie Vinci
===== /glock/media/movies/The Da Vinci Detective (2006) [480p]/The Da Vinci Detective (2006) [480p].mkv (1277 MB) ======
===== /glock/media/uhd/The Da Vinci Code (2006)/The Da Vinci Code (2006).mkv
[chuck@lizum ~.1999]$ movie Demons
===== /glock/media/uhd/Angels & Demons (2009)/Angels & Demons (2009).mkv
[chuck@lizum ~.2000]$
Here you can see I get all the posters without any problems.
If you need help with renaming rules so you can use a renaming tool to help you, I will share what I have.
I did as you recommended, but the result is the same.
ls -la /media/bigmedia/serial/my/From/
total 24
drwxrwxrwx 4 100110 100119 4096 Aug 20 14:00 .
drwxrwxrwx 149 1000 1000 12288 Aug 20 14:00 ..
drwxrwxr-x 2 101000 101000 4096 Aug 20 14:33 'Season 01'
drwxrwxr-x 2 101000 101000 4096 Aug 20 14:34 'Season 02'
ls -la /media/bigmedia/serial/my/From/Season\ 01
total 28367684
drwxrwxr-x 2 101000 101000 4096 Aug 20 14:33 .
drwxrwxrwx 4 100110 100119 4096 Aug 20 14:00 ..
-rwxrwxrwx 1 100110 100119 3094035821 Apr 28 2022 "From - S01E01 - Long Day's Journey Into Night.mkv"
-rwxrwxrwx 1 100110 100119 2902645147 Apr 28 2022 'From - S01E02 - The Way Things Are Now.mkv'
-rwxrwxrwx 1 100110 100119 3050517820 Apr 28 2022 'From - S01E03 - Choosing Day.mkv'
-rwxrwxrwx 1 100110 100119 2804855807 Apr 28 2022 'From - S01E04 - A Rock and a Farway.mkv'
-rwxrwxrwx 1 100110 100119 2809505733 Apr 28 2022 'From - S01E05 - Silhouettes.mkv'
-rwxrwxrwx 1 100110 100119 2834992491 Apr 28 2022 'From - S01E06 - Book 74.mkv'
-rwxrwxrwx 1 100110 100119 2924591892 Apr 28 2022 'From - S01E07 - All Good Things.mkv'
-rwxrwxrwx 1 100110 100119 3231998595 Apr 28 2022 'From - S01E08 - Broken Windows, Open Doors.mkv'
-rwxrwxrwx 1 100110 100119 2622583369 Apr 28 2022 'From - S01E09 - Into the Woods.mkv'
-rwxrwxrwx 1 100110 100119 2772710094 Apr 28 2022 "From - S01E10 - Oh, the Places We'll Go.mkv"
after changing the naming and structure, did you?
- Scan Files
- Refresh All Metadata ?
Question: Did you use ' or " in your names or is that your command line showing them?
Yes. Updated both the metadata and scanned the files.
’ and " is both in the title of episodes of shows that display poster and not.
I can’t figure out why there are ’ and "
There should not be any ' or " in the actual names.
Try it this way? find will not add quotes
[chuck@lizum ~.1999]$ cd /glock/media/tv*/*Rookie*
[chuck@lizum The Rookie.2000]$ find . -print
./Season 01
./Season 01/The Rookie - S01E05 - The Roundup.mkv
./Season 01/The Rookie - S01E13 - Caught Stealing.mkv
./Season 01/The Rookie - S01E16 - Greenlight.mkv
./Season 01/The Rookie - S01E01 - Pilot.mkv
./Season 01/The Rookie - S01E02 - Crash Course.mkv
./Season 01/The Rookie - S01E03 - The Good, the Bad and the Ugly.mkv
./Season 01/The Rookie - S01E04 - The Switch.mkv
./Season 01/The Rookie - S01E06 - The Hawke.mkv
./Season 01/The Rookie - S01E07 - The Ride Along.mkv
./Season 01/The Rookie - S01E09 - Standoff.mkv
./Season 01/The Rookie - S01E10 - Flesh and Blood.mkv
./Season 01/The Rookie - S01E11 - Redwood.mkv
./Season 01/The Rookie - S01E15 - Manhunt.mkv
./Season 01/The Rookie - S01E12 - Heartbreak.mkv
./Season 01/The Rookie - S01E14 - Plain Clothes Day.mkv
./Season 01/The Rookie - S01E17 - The Shake Up.mkv
./Season 01/The Rookie - S01E18 - Homefront.mkv
./Season 01/The Rookie - S01E19 - The Checklist.mkv
./Season 01/The Rookie - S01E20 - Free Fall.mkv
./Season 01/The Rookie - S01E08 - Time of Death.mkv
./Season 02
./Season 02/The Rookie - S02E05 - Tough Love.mkv
./Season 02/The Rookie - S02E01 - Impact.mkv
./Season 02/The Rookie - S02E10 - The Dark Side.mkv
./Season 02/The Rookie - S02E03 - The Bet.mkv
./Season 02/The Rookie - S02E02 - The Night General.mkv
./Season 02/The Rookie - S02E04 - Warriors and Guardians.mkv
./Season 02/The Rookie - S02E06 - Fallout.mkv
./Season 02/The Rookie - S02E09 - Breaking Point.mkv
./Season 02/The Rookie - S02E07 - Safety.mkv
./Season 02/The Rookie - S02E08 - Clean Cut.mkv
./Season 02/The Rookie - S02E11 - Day of Death.mkv
./Season 02/The Rookie - S02E12 - Now and Then.mkv
./Season 02/The Rookie - S02E13 - Follow-Up Day.mkv
./Season 02/The Rookie - S02E14 - Casualties.mkv
./Season 02/The Rookie - S02E16 - The Overnight.mkv
./Season 02/The Rookie - S02E17 - Control.mkv
./Season 02/The Rookie - S02E18 - Under the Gun.mkv
./Season 02/The Rookie - S02E15 - Hand-Off.mkv
./Season 02/The Rookie - S02E20 - The Hunt (2).mkv
./Season 02/The Rookie - S02E19 - The Q Word (1).mkv
./Season 03
./Season 03/The Rookie - S03E01 - Consequences.mkv
./Season 03/The Rookie - S03E03 - La Fiera.mkv
./Season 03/The Rookie - S03E04 - Sabotage.mkv
./Season 03/The Rookie - S03E05 - Lockdown.mkv
./Season 03/The Rookie - S03E02 - In Justice.mkv
./Season 03/The Rookie - S03E07 - True Crime.mkv
./Season 03/The Rookie - S03E06 - Revelations.mkv
./Season 03/The Rookie - S03E08 - Bad Blood.mkv
./Season 03/The Rookie - S03E09 - Amber.mkv
./Season 03/The Rookie - S03E10 - Man of Honor.mkv
./Season 03/The Rookie - S03E11 - New Blood.mkv
./Season 03/The Rookie - S03E12 - Brave Heart.mkv
./Season 03/The Rookie - S03E14 - Threshold.mkv
./Season 03/The Rookie - S03E13 - Triple Duty.mkv
./Season 04
./Season 04/The Rookie - S04E01 - Life and Death.mkv
./Season 04/The Rookie - S04E11 - End Game.mkv
./Season 04/The Rookie - S04E03 - In the Line of Fire.mkv
./Season 04/The Rookie - S04E02 - Five Minutes.mkv
./Season 04/The Rookie - S04E04 - Red Hot.mkv
./Season 04/The Rookie - S04E05 - A.C.H.mkv
./Season 04/The Rookie - S04E08 - Hit and Run.mkv
./Season 04/The Rookie - S04E06 - Poetic Justice.mkv
./Season 04/The Rookie - S04E07 - Fire Fight.mkv
./Season 04/The Rookie - S04E09 - Breakdown.mkv
./Season 04/The Rookie - S04E10 - Heart Beat.mkv
./Season 04/The Rookie - S04E12 - The Knock.mkv
./Season 04/The Rookie - S04E13 - Fight or Flight.mkv
./Season 04/The Rookie - S04E14 - Long Shot.mkv
./Season 04/The Rookie - S04E18 - Backstabbers.mkv
./Season 04/The Rookie - S04E16 - Real Crime.mkv
./Season 04/The Rookie - S04E15 - Hit List.mkv
./Season 04/The Rookie - S04E17 - Coding.mkv
./Season 04/The Rookie - S04E19 - Simone.mkv
./Season 04/The Rookie - S04E20 - Enervo.mkv
./Season 04/The Rookie - S04E21 - Mother’s Day.mkv
./Season 04/The Rookie - S04E22 - Day in the Hole.mkv
./Season 05
./Season 05/The Rookie - S05E03 - Dye Hard.mkv
./Season 05/The Rookie - S05E02 - Labor Day.mkv
./Season 05/The Rookie - S05E01 - Double Down.mkv
./Season 05/The Rookie - S05E04 - The Choice.mkv
./Season 05/The Rookie - S05E05 - The Fugitive.mkv
./Season 05/The Rookie - S05E06 - The Reckoning.mkv
./Season 05/The Rookie - S05E07 - Crossfire.mkv
./Season 05/The Rookie - S05E08 - The Collar.mkv
./Season 05/The Rookie - S05E09 - Take Back.mkv
./Season 05/The Rookie - S05E10 - The List.mkv
./Season 05/The Rookie - S05E11 - The Naked and the Dead.mkv
./Season 05/The Rookie - S05E12 - Death Notice.mkv
./Season 05/The Rookie - S05E13 - Daddy Cop.mkv
./Season 05/The Rookie - S05E14 - Death Sentence.mkv
./Season 05/The Rookie - S05E15 - The Con.mkv
./Season 05/The Rookie - S05E16 - Exposed.mkv
./Season 05/The Rookie - S05E17 - The Enemy Within.mkv
./Season 05/The Rookie - S05E18 - Double Trouble.mkv
./Season 05/The Rookie - S05E19 - A Hole in the World.mkv
./Season 05/The Rookie - S05E20 - S.T.R.mkv
./Season 05/The Rookie - S05E21 - Going Under.mkv
./Season 05/The Rookie - S05E22 - Under Siege.mkv
find . -print
./Season 01
./Season 01/From - S01E07 - All Good Things.mkv
./Season 01/From - S01E10 - Oh, the Places We'll Go.mkv
./Season 01/From - S01E03 - Choosing Day.mkv
./Season 01/From - S01E05 - Silhouettes.mkv
./Season 01/From - S01E02 - The Way Things Are Now.mkv
./Season 01/From - S01E08 - Broken Windows, Open Doors.mkv
./Season 01/From - S01E04 - A Rock and a Farway.mkv
./Season 01/From - S01E01 - Long Day's Journey Into Night.mkv
./Season 01/From - S01E06 - Book 74.mkv
./Season 01/From - S01E09 - Into the Woods.mkv
./Season 02
./Season 02/From - S02E01 - Strangers in a Strange Land.mkv
./Season 02/From - S02E07 - Belly of the Beast.mkv
./Season 02/From - S02E03 - Tether.mkv
./Season 02/From - S02E05 - Lullaby.mkv
./Season 02/From - S02E06 - Pas de Deux.mkv
./Season 02/From - S02E04 - This Way Gone.mkv
./Season 02/From - S02E09 - Ball of Magic Fire.mkv
./Season 02/From - S02E10 - Once Upon a Time....mkv
./Season 02/From - S02E08 - Forest for the Trees.mkv
./Season 02/From - S02E02 - The Kindness of Strangers.mkv
I’ve created a “test series” for FROM
I now understand why you’re getting the names you are.
" is because there exists a ' in the title.
[chuck@lizum tv.2008]$ ll -R From
total 64
drwxrwxr-x 4 chuck chuck 52 Aug 20 15:51 ./
drwxr-xr-x 960 chuck chuck 32768 Aug 20 15:51 ../
drwxrwxr-x 2 chuck chuck 4096 Aug 20 15:52 Season 01/
drwxrwxr-x 2 chuck chuck 4096 Aug 20 15:52 Season 02/
From/Season 01:
total 84
drwxrwxr-x 2 chuck chuck 4096 Aug 20 15:52 ./
drwxrwxr-x 4 chuck chuck 52 Aug 20 15:51 ../
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E01 - Long Day's Journey Into Night.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E02 - The Way Things Are Now.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E03 - Choosing Day.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E04 - A Rock and a Farway.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E05 - Silhouettes.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E06 - Book 74.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E07 - All Good Things.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E08 - Broken Windows, Open Doors.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E09 - Into the Woods.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S01E10 - Oh, the Places We'll Go.mkv
From/Season 02:
total 84
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E01 - Strangers in a Strange Land.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E02 - The Kindness of Strangers.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E03 - Tether.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E04 - This Way Gone.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E05 - Lullaby.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E06 - Pas de Deux.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E07 - Belly of the Beast.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E08 - Forest for the Trees.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E09 - Ball of Magic Fire.mkv
-rw-r--r-- 1 chuck chuck 256 Aug 20 15:46 From - S02E10 - Once Upon a Time….mkv
[chuck@lizum tv.2009]$
there is possibly a DB problem.
Have you used my tool to attempt DB cleanup ?
I took advantage of your tool. No results yet. Now I will try to check the problem with ’
Corrected the title of the entire series library. The problem remains. There are series with and without ’ and ". Are there any other solutions?
