Server Version#: Version 4.84.1
I keep getting this repeating log. It looks like it continues, but I’m not 100% sure and then my activity bar looks as pictured below. I have tried to go back and figure out what files, and I can looked in the folder Music Analysis 3 and will sometimes have Music Analysis 3 (processing) as well.
Jul 24, 2022 10:49:03.437 [0x14a7c5f8fb38] Debug — [MusicAnalysis] Analyzing 5 albums in section 3.
Jul 24, 2022 10:49:03.450 [0x14a7c5f8fb38] Debug — [MusicAnalysis] MusicAnalysis: Analyzing album 466104 ( - ).
Logs:
Plex Media Server Logs_2022-07-23_21-28-59.zip (3.7 MB)
Bad files by any chance ? I see a bunch of Track has no audio stream.. Example below …
Jul 23, 2022 21:22:13.744 [0x15226e2c8b38] DEBUG - Scanner: Processing directory /music/Casting Crowns (CCM Group)/The Altar and the Door (2007) (parent: yes)
Jul 23, 2022 21:22:13.746 [0x1522a92ccb38] DEBUG - [MusicAnalysis] MusicAnalysis: Analyzing album 466104 ( - ).
Jul 23, 2022 21:22:13.753 [0x1522a92ccb38] DEBUG - [MusicAnalysis] Decoding 11 files for input to the analyzer.
Jul 23, 2022 21:22:13.753 [0x1522a92ccb38] ERROR - [MusicAnalysis] Track has no audio stream.
Yeah I’ve tried to go thru each one that I can find and delete those. What I can’t seem to find is the 5 Albums in section 3 and album 466104 ( - ).
I have deleted any that had an actual directory listed.
Did you rescan and empty the trash in plex after deleting ? You might even need to plex dance the album/artist.
I thought so, but I will do it again now and confirm. Thanks for the suggestion.
So I verified that I emptied the trash and have done the plex dance and still get the error as follows:
Jul 25, 2022 10:36:28.067 [0x14d118402b38] Debug — Scanner: Processing directory /music/David Guetta/GRRRR (2009) (parent: yes)
Jul 25, 2022 10:36:28.072 [0x14d118402b38] Debug — Activity: updated activity 010cfc19-148f-4e58-a852-318863f4851a - completed 0.0% - Scanning Music
Jul 25, 2022 10:36:28.073 [0x14d118402b38] Debug — Activity: updated activity 010cfc19-148f-4e58-a852-318863f4851a - completed 99.0% - Scanning Music
Jul 25, 2022 10:36:28.073 [0x14d118402b38] Debug — Scanner [Plex Music]: Idle and left with 1 media items.
Jul 25, 2022 10:36:28.759 [0x14d118402b38] Debug — MusicAnaysis: Not kicking off analysis because section 3 was active already.
Jul 25, 2022 10:36:28.759 [0x14d118402b38] Debug — Activity: updated activity 010cfc19-148f-4e58-a852-318863f4851a - completed 100.0% - Scanning Music
Jul 25, 2022 10:36:29.188 [0x14d118402b38] Debug — Activity: updated activity 45ad0c3a-d48b-45af-a07e-28b2373fb6a5 - completed 0.0% - Scanning Music
Jul 25, 2022 10:36:29.352 [0x14d112e6cb38] Debug — [MusicAnalysis] Activity: Ended activity f354e44c-dc64-473a-b06e-a46d0668cc46.
Jul 25, 2022 10:36:29.353 [0x14d112e6cb38] Debug — [MusicAnalysis] Indexes completed.
Jul 25, 2022 10:36:29.391 [0x14d1191bdb38] Debug — [MusicAnalysis] Fetching all analysis data from tracks from section 3.
Jul 25, 2022 10:36:29.392 [0x14d1191bdb38] Debug — [MusicAnalysis] Activity: updated activity 89e665f2-f4f2-4769-a22d-b73de4a586e6 - completed 20.0% - Sonic Analysis
Jul 25, 2022 10:36:29.395 [0x14d112e6cb38] Debug — [MusicAnalysis] Activity: registered new activity eae7268e-2679-4970-9280-68b330ce7a2d - “Sonic Analysis”
Jul 25, 2022 10:36:29.836 [0x14d112e6cb38] Debug — [MusicAnalysis] Analyzing 5 albums in section 3.
Jul 25, 2022 10:36:29.836 [0x14d112e6cb38] Debug — [MusicAnalysis] Activity: updated activity eae7268e-2679-4970-9280-68b330ce7a2d - completed 0.0% - Sonic Analysis
Jul 25, 2022 10:36:29.859 [0x14d112e6cb38] Debug — [MusicAnalysis] MusicAnalysis: Analyzing album 466104 ( - ).
Jul 25, 2022 10:36:29.868 [0x14d112e6cb38] Debug — [MusicAnalysis] Decoding 11 files for input to the analyzer.
Jul 25, 2022 10:36:29.868 [0x14d112e6cb38] Error — [MusicAnalysis] Track has no audio stream.
Jul 25, 2022 10:36:29.868 [0x14d112e6cb38] Debug — [MusicAnalysis] Killing job.
Jul 25, 2022 10:36:29.868 [0x14d112e6cb38] Debug — [MusicAnalysis] Activity: updated activity eae7268e-2679-4970-9280-68b330ce7a2d - completed 100.0% - Sonic Analysis
Jul 25, 2022 10:36:30.626 [0x14d118402b38] Debug — Scanning Music using en(Plex Music) with 1 current media items and 1 section locations in the database.
Jul 25, 2022 10:36:30.626 [0x14d118402b38] Debug — Performing a scan with ‘Plex Music’ (language: en virtual: 0).
Jul 25, 2022 10:36:30.626 [0x14d118402b38] Debug — * Scanning /music/David Guetta/Permanence (2022)
Can you please provide the media info about this track?
For it to say there is no audio stream makes no sense. The codec should be supported (?)
I’m not sure how I’m supposed to know what track that is though.
That’s not a file name listed in the parent folder of: Jul 25, 2022 10:36:28.067 [0x14d118402b38] Debug — Scanner: Processing directory /music/David Guetta/GRRRR (2009) (parent: yes)
So, I’m kind of lost on how to know what the file is and what the issue might be.
I’m going off the excerpt you posted. I presumed you were targeting this section.
The only thing I see in this section is the lack of audio data track.
Can you perhaps give me the full ZIP file to examine?
I have the full zip file posted in the original post. Would you like a newer one downloaded and sent over?
Thanks!
Thank you. i went and asked questions.
The log should look like when performing analysis.
Jul 25, 2022 08:56:22.867 [0x700008f0c000] DEBUG - [MusicAnalysis] MusicAnalysis: Analyzing album 4550334 (Portugal. The Man - Evil Friends).
Your logs look like this:
Jul 23, 2022 21:23:07.960 [0x15226e2c8b38] DEBUG - Scanner: Processing directory /music/Andy Griggs/This I Gotta See (parent: yes)
Jul 23, 2022 21:23:07.966 [0x1522a1bc3b38] DEBUG - [MusicAnalysis] MusicAnalysis: Analyzing album 466104 ( - ).
Jul 23, 2022 21:23:07.972 [0x1522a1bc3b38] DEBUG - [MusicAnalysis] Decoding 11 files for input to the analyzer.
Jul 23, 2022 21:23:07.972 [0x1522a1bc3b38] ERROR - [MusicAnalysis] Track has no audio stream.
Jul 23, 2022 21:23:07.972 [0x1522a1bc3b38] DEBUG - [MusicAnalysis] Killing job.
Jul 23, 2022 21:23:07.972 [0x1522a1bc3b38] DEBUG - [MusicAnalysis] Activity: updated activity 426c5b40-14f6-4985-b57a-66745c1f2461 - completed 100.0% - Sonic Analysis
Please notice there is no ( Artist - Album name ) information.
The only way to find these files is by direct query of the DB.
- Stop Plex
- Get into the databases directory (under
Plex Media Server/Plug-in Support/Databases)
- We must perform direct sqlite query to find the title / path
sqlite3 com.plexapp.plugins.library.db
select title from metadata_items where id=466104;
From your logs, something in the Andy Griggs directory seems to be the problem.
The query of the DB should reveal the exact title.
Thank for the help so far. I went through to the location and searched for “466104” and get this:
I’m not familiar with that tool but from what that shows, anything with local:// is not matched at all.
Seeing that ‘title’ is blank confirms something’s not right.
Have you performed a physical (directory browser) inspection to see all the files have a valid size and can play?
It does look like there are some adjacent files (have the same 466104 ID).
do those titles make sense?
So the other files played fine, I’m not sure how I get this line corrected to stop throwing the error though. Is there a way to clear this line or two out of the database. I’m just using a sql lite browser to look at the database.
Is there any way to fix the DB to remove the troubled entries?
