@OttoKerner How many collections are too many? I have about 100 automatically generated collections in my Movies library. I do not believe I have ever had any collections in the Music library.
I have started adding music back letter by letter. I am pausing after each add to make sure all of the processing has happened.
Side Note: I am still unable to manually optimize the database without crashing the system.
I have no further ideas on how to go about your issues. Maybe the amount of items is just too much for that little NAS box?
I guess if you could put more RAM into it, there might be some improvement.
Did you ever manipulate the “Database Cache Size (MB)” preference? Default is 20 MB. Definitely avoid raising that to over 100 MB. It is not a file cache.
The QNAP is a monster, and should be able to handle this kinda stuff with ease. Has 64gb of RAM behind the Xeon processor. It was running absolutely fine on a sizeable music library for years up till a few months ago.
Plex music without sonic analysis would be a bummer for sure.
How many tracks do you have? Is there some insane amount or something? I have 200k tracks and it’s fine here and in my head that’s a lot.
Also have you tried deleting the sonic analysis databases letting them regenerate? They are in a subfolder where the main database resides. There should be 3 of them. Note that I have not tried deleting then myself so I don’t know if it’s a bad idea doing so.
I’m going to wager my library is about that size. I’ll have a better answer in a few days. I’m adding it all back in each letter by artist.
I have not tried deleting the sonic analysis database. I had deleted the entire Music Library and operated like that for several weeks until a few posts back where I tried putting them back in which caused a new sonic analysis scan. It worked great, with sonic analysis till I reached the C’s.
I’d wager I have some files in there causing the issue, but I’d like to know for sure before trying extreme things.
Sonic Analysis is disabled, but it now appears that I have looping music scans. I dropped the full library yesterday. It will scan for a while, stop, and then scan again.
Do you want Sonic Analysis enabled or disabled before the attempt?
I have removed the files from the library again to stop the scans. Pretty sure this is easily reproduceable.
Nabbed this after an uninitiated scan completed. Another scan has started as I type. Let me know what else you need. I’m going to leave it rolling until I’m told otherwise.
You have “Scan my library automatically” and “Include music libraries in automatic updates” enabled so it’s looking at filesystem changes and triggering a scan each this happens.
Looks like you have constant changes to files in your music paths, like this:
Jul 31, 2025 12:29:35.220 [139632596650808] INFO - Library section 10 (Music) will be updated because of a change in “/share/ZFS27_DATA/Media/Music/Rush/1996 - Working Man - A Tribute To Rush/1996 - Working Man - A Tribute To Rush.m3u”
This is constantly triggering scans. To remedy this you can check why these files are constantly changing or disable automatic updates for music libraries.
Super interesting… I looked up that specific Rush file in Explorer and I am literally watching the Date Modified change before my eyes.
I’ll dig into this. Assuming that might also be causing the Sonic Analysis issues? I’ve had Plex with auto scan settings since the dawn of time. Odds favor some other piece of software is mucking the directories.
Don’t think so. No scans currently running. I manually deleted a few of these M3U files, and they’re recreating themselves. I disabled QNAPs Multimedia Console which has caused me headaches in the past as a first step. Will let you all know what I find.
I believe it to be a QNAP issue, as the owner of the file is my server name, and admin name.
Is there any chance Plex makes an alteration to M3U files when it scans? I seem to have stopped them from being auto-recreated, but the ones that still exist seem to change their Date Modified concurrent with Plex scans?
I have removed Multimedia Console from the QNAP, as I don’t use it for anything. It is entirely possible that it was the culprit for creating the M3U files, as they stopped recreating the moment I disabled it.
Putty’d in and used the following command to eradicate errant M3U files (directory is mine, replace with your own)
find /share/Media/Music -name “*.m3u” -type f -delete
This seems to have removed the problem files from the system and stopped the scans. No idea where they came from, or how long they’ve existed given that they updated nearly every 60 seconds or less. Neighboring files (non FLAC) with similar file names were dated several years earlier, so the M3U files “could” have always been there, but there’s no way to know.
I have re-enabled Sonic Analysis and will report back tomorrow to see if that loop has been solved as well.
If I have auto scans enabled (which I have had since the dawn of time), and Plex does make an alteration upon scanning a M3U file, would that not cause a scan loop?
Sadly not a music guy, only a QNAP guy, so that would be a Q for @drzoidberg33
But when said, if so, then that would be the first time in history Plex ever altered peoples data, and a lot more folks would be impacted, so highly doubt that
Uninitiated library scans appear to have stopped, and a full library Sonic Analysis has completed over the weekend. I feel confident that this issue has been solved by the removal of errant .m3u files.
I still do not now what was creating or updating them. I sincerely appreciate the look into the logs that lead to solving the issue for me. Happily used PlexAmp all weekend.
