Sonic Analysis - Not running when music added on one library only
Server Version#: 1.32.6.7557
Not sure which log is the useful here, but I can provide if needed.
I have Audio Sonic analysis set to run as a schedule task and when new media is added. I have two music libraries on the same server. One works as expected, the other larger library does not perform sonic analysis when my music is added. It DOES seem to perform the analysis as a scheduled task because results can be seen the next day. I’ve triple checked individual library settings and general settings and can’t find a cause. This used to work no problem for a long time, but stopped working correctly a few months ago.
Another interesting note. I typically will add a few (2-5) albums at a time. When the analysis runs as a scheduled task, the most recent album does not display analysis results. It will only share results after I add more albums and the task runs overnight (with the newly most recently added showing no results).
I’ve also found a couple of albums that have never shown any results. My library is 100k+ tracks.
I’m a bit at a loss here. Happy to provide more information if it could help.
