I’ve updated my server, and set the necessary server options per the blog post
My questions are; is there a way to initiate the library analysis manually on an existing media library, or do I have to wait for the maintenance period?
What happens if the scan doesn’t complete within the maintenance period window?
I am running on a QNAP NAS. I have enabled Analyze audio tracks for sonic features and enabled Sonic Analysis for the Music Library. Under manage library, I clicked analyze. Nothing shows on the Dashboard. Under alerts, I can see see it processing individual albums, It completes in a reasonable time frame. But I do not believe sonic analysis occurred. I added albums to try and trigger the analysis to start. And I have gone a few nights where the scheduled analysis should have occurred. I have downloaded the log (zip) file – contains 150 files. Looking at the com.pleapp.agents.plexmusic.log, I cannot tell if the Sonic Analysis is occurring.
Where can I determine if Sonic Analysis is occurring? Is there a different log to look at?
I am running Version 1.24.0.4930 which is the current version for the QNAP NAS.
THanks for the feedback… doesnt work with me, if i filter by MusicAnalysis i see a blank screen. As most times, the problem is for sure in front of the screen and not at the server
That machine should support the sonic analysis/features.
You probably need to expand that maintenance slot beyond the currently scheduled 1 hour. Keep in mind the server will still execute its daily chores and should only afterwards start executing the sonic analysis.
Give the server some time to finish its regular jobs. The analysis should kick in at some point during the maintenance slot.
I’m not sure when the maintenance job is queuing it’s tasks (e.g. if this is happening exactly at the start time or if it needs some more notice)… at worst the job should be on the maintenance agenda for tomorrow. Keep in mind this might take quite some time on a Celeron.
So it was supposed to run overnight between 2:00am and 5:00am but I don’t know that anything happened which is why I reset the maintenance to the 11:00am to 12:00am time frame to see if I could see anything. As I type this, the server is completely idle.
I get a little weirdness with sonic scanning behavior - Running on a Windows 10 machine, got about 240GB of music. I had the maintenance window set to 2-5AM, and what’s strange is that I can’t see how far the sonic scanning has gotten so far.
I’ve also been manually triggering scans, and eventually it get started on sonic scanning. At that point, the status message says it’s scanning like 3 or 4 albums. That’s over in about 10 minutes, then I can just keep going through the same routine.
