Server Version#:1.25.2.5319
Player Version#: 8.27.2.29938
I have some very extrange situation while playing some mkvs supposed to have the same video stream. The file #1 plays fine, TV recognize the dolby vision stuff, etc. and everything is correct. But with file #2 TV doesn’t recognize the dolby vision.
I have the same problem with another movie file with same Dolby Vision profile / level that has the same problem of dolby vision not being recognized by the TV.
Is there any way to try to figure out what’s going on ?
Thanks in advance.
Media info file #1:
Media
Duration 57:11
Bitrate 15080 kbps
Width 3840
Height 2160
Aspect Ratio 1.78
Video Resolution 4K
Container MKV
Video Frame Rate 24p
Video Profile main 10
Part
Duration 57:11
File Dexter New Blood - s01e01 - Cold Snap.mkv
Size 6.03 GB
Container MKV
Codec HEVC
Bitrate 14695 kbps
D O V I B L Present true
D O V I Level 6
D O V I Present true
D O V I Profile 5
D O V I R P U Present true
D O V I Version 1.0
Bit Depth 10
Chroma Subsampling 4:2:0
Coded Height 2160
Coded Width 3840
Color Range pc
Frame Rate 23.976 fps
Height 2160
Level 5.0
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K (HEVC Main 10)
Extended Display Title 4K (HEVC Main 10)
Codec AC3
Channels 6
Bitrate 384 kbps
Language English
Language Tag en
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Display Title English (AC3 5.1)
Extended Display Title English (AC3 5.1)
Codec SRT
Language English
Language Tag en
Title English
Display Title English (SRT)
Extended Display Title English (SRT)
Codec SRT
Language Spanish
Language Tag es
Format SRT
Display Title Spanish (SRT External)
Extended Display Title Spanish (SRT External)
Media info file #2:
Media
Duration 52:32
Bitrate 29912 kbps
Width 3840
Height 2160
Aspect Ratio 1.78
Video Resolution 4K
Container MKV
Part
Duration 52:32
File Dexter New Blood - s01e02 - Storm of ■■■■.mkv
Size 5.61 GB
Container MKV
Codec HEVC
Bitrate 14636 kbps
D O V I Level 6
D O V I Profile 5
D O V I Version 1.0
Bit Depth 10
Closed Captions true
Coded Height 2160
Coded Width 3840
Color Range pc
Height 2160
Level 5.0
Profile main 10
Ref Frames 1
Width 3840
Codec EAC3
Channels 6
Bitrate 640 kbps
Language English
Language Tag en
Display Title English (EAC3 5.1)
Extended Display Title English (EAC3 5.1)
Codec EIA_608
Bitrate 14636 kbps
Embedded In Video 1
Display Title Unknown (Closed Captions)
Extended Display Title Unknown (Closed Captions)
Codec SRT
Language English
Language Tag en
Codec SRT
Language English
Language Tag en
Title SDH
Extended Display Title SDH (English SRT)
Codec SRT
Language Spanish
Language Tag es
Format SRT
