I suppose the important aspect of the 1st screenshot is that your stream is considered to be „remote“, not „indirect“.
Do you get the same result streaming wired/wireless?
Hi Tom, yes the PMS is running on a Synology NAS in town A (connected in Ethernet to fibre) while the client TV is running in a town B (with ~35Mbps of download speed max)
And this is where I have my little riddle:
Everything being the same, I have NO issue when the TV (in remote town B) is connected to WiFi with download speeds of ~35Mbps,
vs. I get buffering and stuttering issues if connected to Ethernet with download speeds of a couple of Mbps only.
And it’s specific to Plex because the same TV, connected to the same Ethernet will achieve 35Mbps on Amazon Prime for instance.
FYI yesterday I shifted back to Ethernet after having used WiFi for weeks… and surprisingly it worked ok
I cannot understand
Let’s see how long it works with Ethernet but if not it’s not a systematic issue, it’ll be hard to find a fix.
