There is a little inconvenience that I couldn’t find a solution yet. From time to time that a device access a library we might see it sorted alphabetically. I’d like that the server default option to be changed to be by year, is it possible? If yes, what are the steps?
No, the default is always by title. However, if you change the filter/sort, the client should remember and reuse that same filter/sort next time, until you change it.
As an user I feel that we should look for an improvement on the next server update releases to be optional to modify the default. This would be very handy for some of people that are not familiar with doing the change, specially if we have more than one library.
I can report that I saw the clients losing the filter/sort and having to apply again the same settings.
Thank you and hopefully that this request/feedback pass through to the developer team for future improvements.
Plex Version 4.8.4
PMS Version 1.18.4.2171
Any client Android phones, Laptops or Nvidia Shield after one or two days they reset to the alphanumerical order in the libraries
Should I give you access to my server to experience the issue?
In Plex Web, when you notice the change reverting, are you still taken to the library tab? Recommended is the default, so if something is removing this information, it should also take you back to Recommended.
That information is stored in the database. Can you PM me a zipped copy of your database as it is now. The next time you see the sort fail, grab the database again, before fixing anything, and PM that to me too. Let me know which library you looked at and I will see if that information changed/got removed.
