I have folders for my movies …
action
comedy
so forth…
is it possible to sort by YEAR in the folders instead of going alphabetical ??
If you have COLLECTIONS, that does sort in YEAR…hmmm
side note:
Emby has this feature and it works awesome.
action
comedy
so forth…
side note:
When you say “folders,” do you mean what Plex calls “Libraries,” or are you talking about the Folder View within your Movies Library?
If you mean “Plex Libraries,” then this:
This screenshot is from the android TV app, so it looks a little different, but everything’s in the same place:
If you mean the Folder view within a Library, then, no, Plex doesn’t have that ability. There is this feature request where you may want to add your vote:
correct. Folder view within a Library
