Sound problems with Plex for Mac version 1.104.0.241-2164c90a
Server Version#: 1.41.1.9057
Player Version#: 1.104.0.241-2164c90a
I can’t log anything that doesn’t work in MacOS, the player disables the entire sound control of the OS.
Hello, I’ve been having audio problems since the new version of the Mac Player version. When the player is running, I no longer have access to the sound or the output in the OS. I can’t adjust or switch anything using the keyboard or in the settings menu. The only thing that works is adjusting the volume in the player.
When I close the player, everything works as it should.
Does anyone else have similar problems or has solved them?
The error is reproducible.
