Server Version#: 1.21.3.4046
Player Version#: Browser
Specifically the movie Greenland isn’t showing up in my Plex while all others are.
Folder structure:
Greenland (2020) > Greenland (2020) Remux-2160p.mkv
One thing that is different about this movie is that it is 58GB. Other movies are usually not this large for me.
I have tried analysing, rescanning, renaming but none of it seems to work. If I change the view to folder view. I can see the folder “Greenland (2020)” but it’s empty inside.
Scanning gives me the following results for Greenland:
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/Greenland (2020)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/The Devil to Pay (2019)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/Cut Throat City (2020)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/Project Power (2020)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/Red Shoes and the Seven Dwarfs (2019)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/The Fairy Princess and the Unicorn (2020)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/Keanu (2016)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/Hogar 2020"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/Don't Look Back (2020)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/The Dark and the Wicked (2020)"
Feb 19, 2021 12:41:56.947 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/Mortal (2020)"
Feb 19, 2021 12:41:56.953 [0x7fb04c34e780] DEBUG - Skipping over directory '', as nothing has changed; removing 0 media items from map.
Feb 19, 2021 12:41:56.973 [0x7fb04c34e780] DEBUG - Scanner: Processing directory /var/services/video/Greenland (2020) (parent: yes)
Feb 19, 2021 12:41:56.973 [0x7fb04c34e780] VERBOSE - * Noting that 'Greenland (2020)' was updated at 2021-02-19 00:52:47
Feb 19, 2021 12:41:56.973 [0x7fb04c34e780] VERBOSE - * Taking directory 'Greenland (2020)' (1707) out of the map (107 left)
Feb 19, 2021 12:41:56.973 [0x7fb04c34e780] VERBOSE - Adding file for scanner: "/var/services/video/Greenland (2020)/Greenland (2020) Remux-2160p.mkv"
Feb 19, 2021 12:41:56.974 [0x7fb04c34e780] DEBUG - Skipping over directory 'Greenland (2020)', as nothing has changed; removing 0 media items from map.
Feb 19, 2021 12:41:56.974 [0x7fb04109f700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20Greenland%20%282020%29
Feb 19, 2021 12:41:56.974 [0x7fb04c34e780] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/3c53c6e0-f961-42e4-8bad-82f415bfdd00?percentComplete=%2B0%2E951923072&subtitle=Greenland%20%282020%29
Feb 19, 2021 12:41:56.975 [0x7fb04c34e780] DEBUG - HTTP 200 response from PUT http://127.0.0.1:32400/activities/3c53c6e0-f961-42e4-8bad-82f415bfdd00?percentComplete=%2B0%2E951923072&subtitle=Greenland%20%282020%29
Feb 19, 2021 12:41:56.975 [0x7fb04c34e780] DEBUG - Scanner: Processing directory /var/services/video/tmp (parent: yes)
Feb 19, 2021 12:41:56.975 [0x7fb04c34e780] VERBOSE - * Noting that 'tmp' was updated at 2021-02-19 00:37:49
Feb 19, 2021 12:41:56.975 [0x7fb04c34e780] VERBOSE - * Taking directory 'tmp' (286) out of the map (106 left)
Feb 19, 2021 12:41:56.975 [0x7fb04c34e780] VERBOSE - Adding subdirectory for scanner: "/var/services/video/tmp/completion"
Feb 19, 2021 12:41:56.975 [0x7fb04109f700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20Greenland%20%282020%29
Feb 19, 2021 12:41:56.978 [0x7fb04c34e780] DEBUG - Skipping over directory 'tmp', as nothing has changed; removing 0 media items from map.
Feb 19, 2021 12:41:56.978 [0x7fb04109f700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20tmp
Feb 19, 2021 12:41:56.979 [0x7fb04109f700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20tmp
Feb 19, 2021 12:41:56.980 [0x7fb04c34e780] DEBUG - Scanner: Processing directory /var/services/video/tmp/completion (parent: yes)
Feb 19, 2021 12:41:56.980 [0x7fb04c34e780] VERBOSE - * Noting that 'tmp/completion' was updated at 2020-09-26 18:51:51
Feb 19, 2021 12:41:56.980 [0x7fb04c34e780] VERBOSE - * Taking directory 'tmp/completion' (287) out of the map (105 left)
Feb 19, 2021 12:41:56.999 [0x7fb04c34e780] DEBUG - Skipping over directory 'tmp/completion', as nothing has changed; removing 0 media items from map.
Feb 19, 2021 12:41:56.999 [0x7fb04109f700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20tmp%2Fcompletion
Feb 19, 2021 12:41:56.999 [0x7fb04c34e780] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/3c53c6e0-f961-42e4-8bad-82f415bfdd00?percentComplete=%2B0%2E951923072&subtitle=completion
Feb 19, 2021 12:41:57.000 [0x7fb04109f700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20tmp%2Fcompletion
Feb 19, 2021 12:41:57.001 [0x7fb04c34e780] DEBUG - HTTP 200 response from PUT http://127.0.0.1:32400/activities/3c53c6e0-f961-42e4-8bad-82f415bfdd00?percentComplete=%2B0%2E951923072&subtitle=completion
Feb 19, 2021 12:41:57.001 [0x7fb04c34e780] DEBUG - Scanner: Processing directory /var/services/video/queue (parent: yes)
Analysing however doesn’t show anything about Greenland at all.
Also ran Clean Bundle and Optimize Database.
