I couldn’t find the help section.
Anyway my problem is easy to understand… some of my mp3 files play but they dont send any sound.
Any idea what is going wrong?
Can you help me to understand whats wrong with this file or plex?
I thought plex would deal with all the encodings stuff
heres some info of one of them.
https://imgur.com/a/x8yRp3J
It might help if you told which Plex client type you are using.
But most likely it is simply too low a quality. 22kHz sample rate and just 64 kbps and mono won’t be compatible with all devices.
client or server? client i try both browser on chrome(2 diff pcs) and desktop app for pc. server is the latest for unix (nas)
João Serra, sent from mobile
A sábado, 24/08/2019, 16:25, OttoKerner via Plex Forum plex@discoursemail.com escreveu:
Suddenly the song started working ( via web ) , so i guess it is/was a plex problem… Same computer.
system
Closed
5
