Spinning wheel searching for Tuner
Server Version#: 1.32.8.7639
Player Version#: N/A
Tuner Make/Model: HDFX-4K
Guide/Lineup name: N/A
Using XMLTV?:
Channel number/Name: N/A
I get stuck on a spinning wheel when trying to add tuner. I had the tuner previously setup and working great. I had multiple drive failures that wiped out my PlexDB and some libraries, including my DVR save location. It did not affect my my Plex Server install directory. After the drive failure, my tuner was no longer setup. Now when I go to setup Live TV & DVR it just sits at a spinning wheel, I think searching for the tuner. I can input the IP address manually but it just comes back to the spinning wheel.
Solved: I deleted all of the tv.plex.providers.epg.cloud… files in PlexDB directory…Plug-in Support\Databases folder.
