Unable to re-add HDHomeRun tuner
Server Version#: 1.29.2.6364
Player Version#: 4.96.2
Tuner Make/Model: HDHomeRun FLEX 4K (ID: 10A07A23)
Guide/Lineup name: My Guide
Using XMLTV?: Not any more
Channel number/Name: All
I am unable to add my HDHomeRun tuner after trying to add additional tuners. I was trying to use additional tuners through xteve and disquetv and their custom XMLTV list. They didn’t work as hoped, so I have stopped using the other tuners and now trying to put back just my HDHomerun tuner. The system just hangs on the screen below. “Finding the best guide.” It doesn’t make any progress. Not sure what is hanging it up. Is it trying to pull the old XMLTV? Is there a way to remove all of the old tuner information and let plex rebuild the tuner information?
plex log.txt (72.8 KB)
Delete the DVR and uninstall Dizquetv and hopefully the will clear out the bad tuner entries.
Did that already. Still nothing.
If you have already deleted the DVR and no success. image
Your options would be to:
Restore a db backup from before you added dizque if one exists
Access the database with sqlite and delete the rows in media_provider resources. "DELETE FROM media_provider_resources"
Delete all the db files and start over.
https://support.plex.tv/articles/repair-a-corrupted-database/
Thanks! I deleted all of the old db files and restored the backups and removed the dates.
com.plexapp.plugins.library.db & com.plexapp.plugins.library.blobs.db
Now plex won’t start.
I got it running again. I had to change the user/group permissions.
