Split Apart not appearing for TV Shows
Hi, i’m having a problem with the original Doctor Who on Plex, since each episode has parts Plex just merges them together and TVDB only has the first part. I know there is a Split Apart option for TV Shows but it doesn’t appear for me, and yes i’m on the show page and not the episode page
Server Version#: 3.104.1
You cannot split episodes. Only complete tv shows.
That is not true. TheTVDB actually has each “part” as a separate episode.
(If you are referring to to the first-ever episodes in season 01)
Not sure how you are naming your files but I would just not use part 1 part 2 at the end. Even using Roman numerals Part I Part II will prevent other wise same named files from merging.
I only have some seasons of this, but this is how I have mine named:
Doctor Who (1963)/Season 09/Doctor Who (1963) - s09e01 - Day of the Daleks (1).mkv
Doctor Who (1963)/Season 09/Doctor Who (1963) - s09e02 - Day of the Daleks (2).mkv
Doctor Who (1963)/Season 09/Doctor Who (1963) - s09e03 - Day of the Daleks (3).mkv
Doctor Who (1963)/Season 09/Doctor Who (1963) - s09e04 - Day of the Daleks (2).mkv
Doctor Who (1963)/Season 09/Doctor Who (1963) - s09e09 - The Sea Devils (1).mkv
Thanks for all the replies, i’ve found the problem with how the episodes are named but i’m having a hard time using filebot to match the names correctly
I hope you didn’t pay for Filebot?
Nope i got the free version
Thank god for that.
I cant abide Filebot so hopefully someone else may be able to help.
Personally I let Sonarr do all my TV Show naming. It’s not designed as purely a method to rename files but it does it anyway.
This is basically my problem with FileBot, it thinks every part is the same episode
I don’t use filebot either, but looking at the original naming, It could be bit of struggle to fix those automatically.
And a quick google search does suggest that filebot struggles a bit with Doctor Who.
I am not even sure if sonarr could rename those…
But maybe someone else has an idea
I really hope so, there are way too many episodes to go through manually
I fear you may have to.
The tvdb that Plex uses is very strict.
There is no way it will understand several identical episode numbers all with different episode names.
Just wish i could use filebot more manually, just moving the right names to the right places
Decided to just make another library for it and just organize like the folders are, no matching but i can’t get even that to work
Tell Filebot that you are using Plex, and not Kodi: Plex naming schemes for FileBot
Only do one season at once.
Watch the video tutorial for Filebot ‘manual mode’.
Thank you so much, this is exactly what i needed
