How can I split apart these two items when the “split apart” option isn’t listed?
You need to name them according to the naming standards. The reason you can’t split them is because Plex thinks they are part 1 and part 2 of the same movie and not separate files of the same movie, see here on naming multi-file movies.
You should have:
- Harry Potter and the Deathly Hallows Part 1 (2010).m4v
- Harry Potter and the Deathly Hallows Part 2 (2011).m4v
Having the year at the end will avoid the Plex Scanner from thinking it is a multipart file and also match it correctly. It would be a good idea to perform the Plex Dance on these files and re-add them to the library.
Thanks for you help!!!
No problem
