Does anyone know how to force Plex to split 2-part movies that were released in 2 parts into two separate movies listed in Plex?
The example I have is Harry Potter and the Deathly Hollows. For those who don’t know, it was released as 2 movies with “Part 1” being movie number 1, and “Part 2” being released about a year later. Right now, plex is doing what it normally should do and assuming that the 2 parts are the same movie, just perhaps Disk1 and Disk2 rips. This obviously isn’t the case here. I wanted to split the movies up but I cannot seem to do that in the interface. The best I can do is “Unmatch” but it’s still grouping both files under the “Part 1” header/title.
Can anyone think of a way to split these or otherwise force Plex to ID them as different movies?
Was actually about to post another possible solution I just found. The files used to be arranged like this:
/Movies
Harry Potter and the Deathly Hallows Part 1.mkv
Harry Potter and the Deathly Hallows Part 2.mkv
I changed it to the following and it worked for me as an alternative to the solution from Otto:
/Movies
/Harry Potter and the Deathly Hallows Part 1
/Harry Potter and the Deathly Hallows Part 1.mvk
/Harry Potter and the Deathly Hallows Part 2
/Harry Potter and the Deathly Hallows Part 2.mvk
Guilty here! I experienced the same issue with the same movies and agree that adding the release year to the filename greatly helps in matching metadata.
