I have a large library , the folder has 573 movies
But Plex says that library has 560 movies.
So some of the files are combined with others.
I have no idea what ones they are.
So was looking at a way to find the combined files easily. Instead of clicking on one at a time.
Is there a way to sort or see what files have combined ones in them?
sort by duplicates which will display ones where it thought it was two or more copies/versions of the same movie
Otherwise generally it will movies with parts that might gotten combined as two halves of a movie because of how file naming rules work. Unfortunately there is no easy sort for that as they are not considered duplicates/versions. Files with named the same other wise but end in part1, part2, or a view other variations, are treated as one file for playback in apps that support it https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/#toc-3 . I’m not sure if webtools has an report for that. cc @dane22
WebTools-NG has a module named Find Media that just might be able to assist here
