SSL Certificate Errors
Yes initially password was reset , i see from timestamp.
But latest log show auth was successful yet I’m getting TLS error?
PS - i reinstalled app now and have same issue.
why aren’t you using the 9.x.x app version?
Is there ANY way you can try to connect using IPv4 ?
Plex doesn’t speak IPv6
Yes i can try via IPv4 custom server URL .
But that’s what boggles me. I’ve been using IPv6 for months without any issue till recently.
PS- tried with 9.x and IPv4 and same issue persists.
Logs attached
plex-log-rohitvj-2.zip (222.1 KB)
A
@ChuckPa
Here are my server logs. I just freshly replicated the problem, with debug enabled.
I did also upgrade to latest client on Google Play today too.
Plex Media Server Logs_2022-08-01_19-57-48.zip (3.4 MB)
@jodybrown
Now I see what’s happening.
  1. Your LAN is 172.16.x.x
  2. You’re attempting to access the server via the WAN ADDRESS and use plex.direct
Aug 01, 2022 14:59:29.081 [0x7f877f9d4b38] WARN - [CERT] TLS connection from 172.16.0.3:46112 came in with unrecognized plex.direct SNI name '24-53-255-249.fd993391155a4490a38c4b643fe93492.plex.direct'; using installed plex.direct cert
Aug 01, 2022 14:59:29.094 [0x7f877f9f7b38] WARN - [CERT] TLS connection from 172.16.0.21:57103 came in with unrecognized plex.direct SNI name '24-53-255-249.fd993391155a4490a38c4b643fe93492.plex.direct'; using installed plex.direct cert
Do you have DNS rebinding protection on your modem router?
How are those devices attempting to connect? Manual server address or via Plex.tv ?
@ChuckPa
turns out i DID have dns rebinding protection on my firewall (OPNsense ; it’s a default on)
i toggled it off and downloads worked immediately
i even turned it back on, and it continued to work. perhaps once it works ONCE it’s fine?
i am reluctant to leave it turned off forever (for good reasons)
the only change i made to my network was months ago when i merged my dns server (.21) into my firewall (.3) … (the spinning rust hard drive on my dedicated dns server died)
i can only assume that is the correlation here…
i did not have any manual server addresses set up (under advanced in android app right?) - so i guess using the regular plex.tv method.
I use pfsense. I declare private network: plex.direct in my dns resolver and it’s done.
This allows it to stay on but keep plex as a known allowed private network domain
@ChuckPa Any resolution for my query . Loaded logs for your reference
@rohit533 do you have anything specified in Custom server access URLs?
Yes .
https://my.ipv4.of.server.plex token id.direct.port
First, why - what’s the goal of that entry?
Second, is the token/guid outdated?
Goal of entry is to connect to server behind VPN.
How do i check if token is outdated?
I see this entry in the logs; it appears to be a Tailscale IP address entered as a Custom Server Access URL:
Aug 02, 2022 01:15:24.400 [0xb1aead44] DEBUG - [HCl#2c] HTTP requesting PUT https://plex.tv/devices/7b9bd39903d63ae01e83e5ed25265e406b6804e7?Connection[][uri]=https://100-78-7-1.c4d7b652eefbc6e58e16c5a7f103f688.plex.direct:32400&Connection[][uri]=http://192.168.1.52:32400&httpsEnabled=1&httpsRequired=0&dnsRebindingProtection=0&natLoopbackSupported=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
That’s what’s being pushed up to Plex.
c4d7b652eefbc6e58e16c5a7f103f688 is the server GUID & address that the client is trying to connect to, because that’s what you’ve told it to do with the current Custom server access URL entry. And it’s being rejected, because …
… earlier, there’s this entry:
Aug 02, 2022 01:15:04.996 [0xb64d1e60] DEBUG - [CERT] Subject name is /CN=*.cd7b652eefbc46e58e16c5a7f103f688.plex.direct
Those don’t match. The server knows itself by the cd7b652eefbc46e58e16c5a7f103f688 certificate ID.
Try changing the Custom server access URL entry to just the IP address: https://100.78.7.1:32400. I think Plex will automatically register an entry with the full magic certificate URL.
Edit: Those are awfully similar. Transposition / typo?
But still, try it with just https://100.78.7.1:32400 if that’s the Tailscale IP.
Thanks a ton mate. It is working well now. Thanks a ton again .
Anyway can we mark it as answered ?
To follow up here and educate as we close out
  • I did state/ask about using the host.certID.plex.direct URL. I should have been more clear. Sorry
TO ALL who find this in the future:
  1. NEVER use a plex.direct URL for anything because the CertID will change the next time the certificate updates whichinvalidates the URL.
  2. Use either a FQDN URL or an IP address, both of which are in your control.
Can someone here reset my certificate or give me a new one? I am unable to access my server after doing a factory reset on my Nvidia Shield.
Server Version#: 1.28.0.5999
Player Version#:9.6.0.34226
@JKoblyn
I looked at your plex.tv account. There are no certificate errors of any kind.
However, since you did a factory reset on your Shield,
  1. I can assume all three server entries there are no longer valid ?
  2. Would you like me to remove them so you can complete setup of the server from scratch?
Yes please. Thank you!
@JKoblyn
I’ve removed all the Shield servers from your account.
You can remove the server on the shield and start over if you have one installed.
