Stargate SG-1 Aren't Seen by Plex
Server Version#: 1.14.1.5488
Player Version#: unknown
I just put the files for Stargate into my TV Shows folder. At first it saw SG-1 but not the other series (Universe and Atlantis).
\Stargate\Stargate SG-1
\Stargate\Stargate Universe
\Stargate\Stargate Atlantis
So I removed the main folder for Stargate and just put the 3 series folders on the root of the TV Shows.
Rescanned and it sees the series folders, but noting inside of them.
I tried doing the Plex Dance, but not sure I did it right. Instructions aren’t very precise.
https://support.plex.tv/articles/201543057-why-is-some-of-my-content-not-found/
https://support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
You can delete files, empty trash, re-add, etc. all you want, but with the current public version it don’t work. I’ve been trying to get it to recognize The Last Ship season 5 episodes, and it refuses. Based on what I can see it’s not erasing the original entries.
Ok, so followed those instructions to the T and the same result. My naming for the files is:
Stargate SG-1.S01E01.iNT.DVDRip.XviD-LOCK.ext
Isn’t seen in the folder.
I have Stargate SG-1 in my library and it matches. I have it named as follows:
Stargate.sg1.s01.e03.(1997)
I’m using TheTvDB as my agent if that matters at all.
In PMS, go into TV and sort by folders. What do you see in the Stargate SG-1 folder?
a message that says: ā€œThere are no items in this folder.ā€ Not even the Season folders show up.
I’m using TheTvDB as my #1 agent as well.
Please upload logs, since this might be a permission error
I’m assuming you’re nesting these folders underneath a main folder called ā€œTVā€ or something? If so, don’t nest them under the ā€œStargateā€ folder. It’s probably confusing Plex. Just bring those folders out from the nested folder into the main folder, like this:
Before:
D:\TV\Stargate\Stargate SG-1
D:\TV\Stargate\Stargate Universe
D:\TV\Stargate\Stargate Atlantis
After:
D:\TV\Stargate SG-1
D:\TV\Stargate Universe
D:\TV\Stargate Atlantis
Here’s how I have mine set-up and it seems to be working…
i used filebot to name my series and like you i have a TV folder which i set as root of the library
to my drive it is Drive letter :\TV\Tv Series\Stargate\SG-1 1997\Season # Replace # for the correct season
Season 1 Ep 1 is named Stargate SG-1 - 1x01-02 - Children of the Gods
they matched fine and download correctly however like you see some two parters needed a different naming.
i use thetvdb as my agent and the only time i have ever had issues is when my server account for windows did not have permissions to read and write the files.
That nesting was the first way I did it. I pulled everything out of the Stargate folder and deleted it. Did the Plex Dance and put just 1 season of SG-1 in and Plex saw it. Put the rest in and it only sees Season 1 and Season 10. Nothing in between.
I have a near-identical file naming scheme, but I set up the folders differently, and I leave out the show name since it’s already in the folder:
D:\Television\Stargate SG-1 (1997)\10x10 - The Quest (1).mp4
The D:\Television\ folder is the folder I crawl with Plex. It picks it up perfectly.
then perhaps try this structure for Season 2
Stargate SG-1 - 2x01 - The Serpent’s Lair
Show Name - Season#xEpisode Number - Episode Title
