For some reason a single show, Stargate SG-1, is being placed inside multiple shows during library scans.
I have done the Plex-dance a few times, but for whatever reason, I cannot get this one show to show up correctly or at all.
Episodes for SGSG1 show up correctly identified by S#E# in the wrong shows:
Breaking Bad
Game of Thrones
House
The Walking Dead
The episodes are the right S#E#, i.e. S04E02, but they show up in the wrong show(s).
I have never seen anything like this before.
Stargate SG-1, for this example, has only one valid episode (S07E10) and I see no difference in the naming or anything.
Emby (sorry) sees the shows properly.
They are all named properly (./Stargate SG-1/Season #/Stargate SG-1 S##E##…)
I don’t think it’s a naming issue. Looking at the scanner log it shows that PMS is trying to match each season to a show of that name. So “Stargate SG-1\Season 7” is somehow trying to match to a show called “Season 7”, etc.
A Plex Dance will be the only way to fix this that I can see.
Most of the shows names were simply ‘Stargate SG-1 S##E## [720p].EXT’ or similar. Very few had the episode title and very few had extra hyphens in the names aside from SG-1.
That said, I got it sorted out this morning after plex-dancing a ton of times with no change. It even seemed to get worse and matched one season to Ellen Degeneres. Previously, I think they all matched to existing shows I had.
My solution was three-fold and I am not sure which one did the trick.
I used filebot to rename everything, so now all the files have a ton of hyphens (I didn’t read the replies until after I did). The file names are now ‘Stargate SG-1 - S##E## - TITLE.ext’.
I then altered each file’s hash value so if Plex checked hashes, they would be different.
Lastly, this is probably what resolved it, I renamed the series folder from “Stargate SG-1” to “Stargate SG1 (1997)”.
I finished the dance and moved the folder back into its TV home folder,scanned and voila. All better.
If I didn’t dance so many times before, I would have done one at a time to see what fixed it, but I just did everything, did the dance, and now Plex sees SG1 properly.
It was at the same level as everything else I have:
/media/tv/series_name/season_folders/files
so:
/media/
–tv/
----Stargate SG-1/
------Season 1/
--------files
--------files
--------files
------Season 2
--------files
--------files
--------files
etc…
Library points to /media/tv/.
The folder is right back where it started and fine after what I explained above.
Just a strange one and the first time I ever saw anything that wacky from Plex scans.
