@Aliquam said:
Potentially Optimistic Resolution (for NAS): I originally posted on October 10, 2017- “Here’s my log running v1.9.2.4285. Recording schedule shows five shows from last night (10/10/17) stuck at 100% with nothing appearing in the .grab folder or the respective destination folders after a typical and working recording schedule. There were no error messages. Recordings occur on a 24/7-on home server. I cannot recall which previous version did not have this issue, but recently also noticed that shows were not recorded for the full length of time as set up in the schedule.”Since then I have upgraded to server Version 1.9.4.4325; however, this time around I installed the software as a fresh install as opposed to installing over the existing version and it has been three full days that I have been able to record shows in their entirety, transcode them and watch all programs I selected through the recording schedule. While I only waited these few days to see if this would break, I thought it might be long enough that this solution was stable enough to share.
The steps I took were to completely uninstall the PMS from my server, restart the server and then I signed-out of my Plex account from the web. I next downloaded the latest version of PMS for servers (doesn’t really matter when you download…just sharing the order of steps I took) ensuring the version I downloaded was compatible with my NAS’ processor; I have an Intel Celeron J1900 installed in a QNAP TS-451 (64 bit Version 1.9.4.4325). Note that by removing the server’s PMS you will lose your recording schedule and all settings/preferences; you are doing a fresh/new install as if you hadn’t installed PMS before and this will require you to recreate your libraries, link your tuner, download the latest program guide, etc. After the PMS was up and running, I ran PMS from my server, which launched my web browser so I could log into my Plex account. Afterwards, I went through the motions of recreating my libraries the same way as I originally had them, relinked my tuner, selected all the shows I wanted to record, etc. I did not create a new Plex account and did not change any settings as I had before. Also note you will need to run your setup locally as I originally tried to re-setup my account from work and was not able to connect to my NAS, because I did not yet have remote access. Lastly, I do not plan to upgrade to the latest version since this was not an enjoyable exercise and hoping that the engineers respond to a dedicated paragraph to them below or until they have a permanent fix for this issue and for my operating environment.
Like I said, it’s now been three days full days and I have not run into the same issues as described in my original post. I hope sharing this might help someone else. Since there is a lot activity on this thread, I removed the notifications by email, but if you have any questions, feel free to either PM me or mention me in your post as those notifications are still on. Expect a delay in my reply.
For the Plex engineers, please (1) validate that this may be a potential resolution; a complete and fresh install, (2) it would be great if you can make an easy way to allow us to backup and restore our database which would include all settings/preferences, recording schedule and anything else worth backing up…even better, a check-box list of options we can chose to backup.
Hoping some of you can get up and running as well and looking forward to hearing from the Plex Team!
Maybe an engineer can comment also, but I would guess this isn’t the source of everyone’s problem.
For me channel CBS is my strongest channel and it records flawlessly every time. FOX and NBC are slightly weaker and they usually record fine, but storms will cause them to fail with the 100% bug every time. Then finally there’s ABC which is usually watchable on Windows Media Center, but with lots of glitching, and Plex can never get through a single recording on that channel regardless of weather.
It seems like I shouldn’t get good recordings if Plex had an upgrade glitch, so I wonder if there could be two issues causing the 100% freeze problem. One issue where the transcoder software or settings got corrupted, and another purely related to it’s garbage filtering not handling bad signals.
