Stopped matching anything, but it works on selecting refresh metadata
Server Version#: Version 1.19.4.2935
Player Version#: Version 1.12.1.1253-c29aa096
Plex stopped matching Movies or TV Shows. I can filter them in library and then perform a “refresh metadata” manually and all works fine. Attached is the log for a particular unmatched movie. Apparently I can’t find other records in the logs for this movie, apart from the imdb agent log when I manually did a metadata refresh (and was matched correctly). Where should I look?
Plex Media Scanner.2.log (12.8 KB)
Are these boxes checked?
Settings > Library > Scan my library automatically
Settings > Library > Run a partial scan when changes are detected
Both checked. I also have a script that triggers a command line scan for modified/new folders.
I have found the solurion. If anyone has this issue: if a scan is initialised from command line aparrently you have to also add “–refresh” to force the metadata download…
