Stops playing after a couple of mins of playing
the synology which feeds everything in the house
has got plex on as well
just tried using that one
SYNOLOGY
2:38am mbu10 started playing Deadliest Catch - Clash Of Kings on SHIELD Android TV.
2:32am mbu10 started playing Deadliest Catch - Arctic Hurricane on SHIELD Android TV.Plex Media (6.1 MB)
it is if you tell shield not to play the original and feed it a encoded version ?
trying to play a feed from a friends plex server now, has to go thorugh the same switches as every thing else
this has just stopped as well
so that rules out my server/ synology
only thing left is either my network(switch) is faulty can test by selecting a diffrent wifi AP which does not use the switch
or the client software
fair comment?
so how on earth do i trouble shoot the plex app / Shield then ?
cause at this point in time i have emby working perfectly fine with no problems on the same set up.(it runs on the same server when i start it )
here is the logs ,
when enabled it actually kept hours of logs
sheilds log.txt.txt (1.1 MB)
think this is where is dropped it and started playign the next
Summary
=c736b5d724bb7afc-com-plexapp-android&X-Plex-Token=…atxz
07-31 02:37:53.907 i: [video] Video ended.
07-31 02:37:53.919 i: Fetching [method:GET] https://192.168.2.99:32400/:/timeline?bandwidth=914779&bufferedTime=-408&containerKey=%2FplayQueues%2F30&duration=2494208&guid=com.plexapp.agents.thetvdb%3A%2F%2F78957%2F14%2F6%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F37880&machineIdentifier=2029001cde02df46b459a5ceac2d40066d3b432e&playQueueItemID=1355&ratingKey=37880&state=playing&time=408874&token=...atxz&X-Plex-Client-Identifier=c736b5d724bb7afc-com-plexapp-android&X-Plex-Token=...atxz
07-31 02:37:53.923 i: Fetching [method:GET] https://192.168.2.99:32400/:/timeline?bandwidth=914779&bufferedTime=-408&containerKey=%2FplayQueues%2F30&duration=2494208&guid=com.plexapp.agents.thetvdb%3A%2F%2F78957%2F14%2F6%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F37880&machineIdentifier=2029001cde02df46b459a5ceac2d40066d3b432e&playQueueItemID=1355&ratingKey=37880&state=stopped&time=408874&token=...atxz&X-Plex-Client-Identifier=c736b5d724bb7afc-com-plexapp-android&X-Plex-Token=...atxz
07-31 02:37:53.923 i: [TranscodeSession] Stopping…
07-31 02:37:53.937 i: [HdmiUnplugBehaviour] Disconnecting
07-31 02:37:53.942 i: [BatteryBehaviour] Playback session was 5.5 minutes long.
07-31 02:37:53.942 i: [BatteryBehaviour] Average battery consumption was 0.00 µAh per minute.
07-31 02:37:53.946 i: [FF][MediaPeriod] Releasing.
07-31 02:37:53.948 i: [FF] Releasing demuxer.
07-31 02:37:53.949 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/37880?checkFiles=1&includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:53.966 i: [UpdateRecommendationsService] Canceling the recommendation notifications, because channels are enabled
07-31 02:37:53.974 i: Creating PostPlayActivity.
07-31 02:37:53.983 i: [Boot] PostPlayActivity took 9ms to run create behaviours.
07-31 02:37:53.991 i: Fetching [method:GET] https://192.168.2.99:32400/hubs/metadata/37880/postplay?X-Plex-Token=...atxz&X-Plex-Container-Start=0&X-Plex-Container-Size=50
07-31 02:37:53.993 i: Resuming PostPlayActivity.
07-31 02:37:54.013 i: [UpdateChannelsJob] Starting channel creation job
07-31 02:37:54.061 i: [UpdateChannelsJob] Syncing programs for channel Recommendations (id=12)
07-31 02:37:54.061 i: [UpdateChannelsJob] Syncing programs for channel My Newscast (id=13)
07-31 02:37:54.078 i: Fetching [method:GET] https://192.168.2.99:32400/hubs?X-Plex-Token=...atxz
07-31 02:37:54.078 i: Fetching [method:GET] https://services.provider.plex.tv:443/home/hubs?X-Plex-Client-Identifier=c736b5d724bb7afc-com-plexapp-android&X-Plex-Token=...atxz
07-31 02:37:54.226 i: [UpdateChannelsJob] Syncing programs for Watch Next channel
07-31 02:37:54.226 i: Fetching [method:GET] https://192.168.2.99:32400/hubs?X-Plex-Token=...atxz
07-31 02:37:54.436 i: [MediaSessionHelper] Releasing media session with tag: video
07-31 02:37:54.480 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/20441?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.488 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/20441?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.505 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/20441?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.511 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/117695?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.537 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/117695?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.544 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/17044?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.560 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/17044?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.570 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/117675?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.581 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/117675?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.593 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/38042?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.607 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/38042?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.615 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/37678?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.630 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/37678?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.658 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/26522?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.681 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/117698?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.713 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/37619?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:54.737 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/117695?includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...atxz
07-31 02:37:55.148 i: [UpdateChannelsJob] WATCH NEXT: Removing program for item Deadliest Catch (id=12751)
07-31 02:37:55.158 i: [UpdateChannelsJob] WATCH NEXT: Removing program for item Stan Lee’s Lucky Man (id=12752)
07-31 02:37:55.162 i: [UpdateChannelsJob] WATCH NEXT: Removing program for item The Americans (2013) (id=12753)
07-31 02:37:55.166 i: [UpdateChannelsJob] WATCH NEXT: Removing program for item Harrow (id=12754)
07-31 02:37:55.174 i: [UpdateChannelsJob] WATCH NEXT: Removing program for item Gone (id=12755)
07-31 02:37:55.177 i: [UpdateChannelsJob] WATCH NEXT: Removing program for item Elementary (id=12756)
07-31 02:37:55.182 i: [UpdateChannelsJob] Adding program for item Deadliest Catch (id=12757).
07-31 02:37:55.189 i: [UpdateChannelsJob] Adding program for item Stan Lee’s Lucky Man (id=12758).
07-31 02:37:55.194 i: [UpdateChannelsJob] Adding program for item The Americans (2013) (id=12759).
07-31 02:37:55.199 i: [UpdateChannelsJob] Adding program for item Harrow (id=12760).
07-31 02:37:55.207 i: [UpdateChannelsJob] Adding program for item Gone (id=12761).
07-31 02:37:55.213 i: [UpdateChannelsJob] Adding program for item Elementary (id=12762).
07-31 02:37:56.103 i: [UpdateChannelsJob] Deleted all 17 programs.
07-31 02:37:56.110 i: [UpdateChannelsJob] Adding program for item Deadliest Catch (id=53085).
07-31 02:37:56.115 i: [UpdateChannelsJob] Adding program for item Stan Lee’s Lucky Man (id=53086).
07-31 02:37:56.121 i: [UpdateChannelsJob] Adding program for item The Americans (2013) (id=53087).
07-31 02:37:56.126 i: [UpdateChannelsJob] Adding program for item Harrow (id=53088).
07-31 02:37:56.130 i: [UpdateChannelsJob] Adding program for item Gone (id=53089).
07-31 02:37:56.138 i: [UpdateChannelsJob] Adding program for item Elementary (id=53090).
07-31 02:37:56.144 i: [UpdateChannelsJob] Adding program for item Lost (id=53091).
07-31 02:37:56.155 i: [UpdateChannelsJob] Adding program for item Shameless (US) (id=53092).
07-31 02:37:56.161 i: [UpdateChannelsJob] Adding program for item Intelligence (2014) (id=53093).
07-31 02:37:56.167 i: [UpdateChannelsJob] Adding program for item Killjoys (id=53094).
07-31 02:37:56.172 i: [UpdateChannelsJob] Adding program for item Quantico (id=53095).
07-31 02:37:56.178 i: [UpdateChannelsJob] Adding program for item Avengers: Infinity War (id=53096).
07-31 02:37:56.184 i: [UpdateChannelsJob] Adding program for item Duck Duck Goose (id=53097).
07-31 02:37:56.189 i: [UpdateChannelsJob] Adding program for item Hot Summer Nights (id=53098).
07-31 02:37:56.196 i: [UpdateChannelsJob] Adding program for item Gotti (id=53099).
07-31 02:37:56.201 i: [UpdateChannelsJob] Adding program for item Extinction (id=53100).
07-31 02:37:56.207 i: [UpdateChannelsJob] Adding program for item Breaking In (id=53101).
07-31 02:38:04.228 i: [PostPlay] Playing next because count down ended.
07-31 02:38:04.229 i: [PlayQueueAPIHelperBase] Retrieving play queue with id=30 with repeat flag = 0
07-31 02:38:04.229 i: [PlayQueueAPIHelperBase] Request URL is /playQueues/30?center=1356&includeChapters=1&repeat=0
07-31 02:38:04.229 i: Fetching [method:GET] https://192.168.2.99:32400/playQueues/30?center=1356&includeChapters=1&repeat=0&X-Plex-Token=...atxz
07-31 02:38:04.255 i: Creating VideoPlayerActivity.
07-31 02:38:04.258 i: [Boot] VideoPlayerActivity took 3ms to run create behaviours.
07-31 02:38:04.267 i: [HdmiCaps] Capabilties changed (AudioCapabilities[maxChannelCount=8, supportedEncodings=[2, 4, 5, 6, 7, 8, 13, 14]])
07-31 02:38:04.269 i: [TranscodeSession] Media choice updated
07-31 02:38:04.270 i: [MediaDecisionEngine] Starting media decision for: Deadliest Catch - S14 E07 (part index 0)
07-31 02:38:04.270 i: [MediaDecisionEngine] Provided video item has no streams, checking files…
07-31 02:38:04.270 i: Fetching [method:GET] https://192.168.2.99:32400/library/metadata/37877?checkFiles=1&includeChapters=1&X-Plex-Token=...atxz
07-31 02:38:04.270 i: [MediaSessionHelper] Starting media session with tag: video
07-31 02:38:04.271 i: [MediaSessionHelper] Creating media session with tag: video
07-31 02:38:04.271 i: [video] Unable to report progress to server, since no duration is available.
07-31 02:38:04.274 i: [MediaSessionHelper] Setting media session playback state with tag video and state 3
07-31 02:38:04.286 i: Resuming VideoPlayerActivity.
07-31 02:38:04.293 i: [HdmiUnplugBehaviour] Ignoring sticky intent
07-31 02:38:04.317 i: [MediaDecisionEngine] Transcode server selected: Synology
07-31 02:38:04.317 i: [MediaDecisionEngine] Analyzing media: 1280x720 3180kbps (Container: mkv, Video: h264, Audio: aac)
07-31 02:38:04.325 i: [MediaDecisionEngine] Original quality selected, skipping resolution/bitrate check
07-31 02:38:04.325 i: [video] User maximum h264 profile determined: 51
07-31 02:38:04.325 i: [video] Device recommended h264 profile determined: 52
07-31 02:38:04.350 i: [BufferHelper] Assumed Bitrate: 10000, Segment Count: 1171
07-31 02:38:04.350 i: [BufferHelper] Segment count: 1171
07-31 02:38:04.354 i: Fetching [method:GET] https://192.168.2.99:32400/video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F37877&protocol=*&session=c736b5d724bb7afc-com-plexapp-android&subtitleSize=100&X-Plex-Client-Identifier=c736b5d724bb7afc-com-plexapp-android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D6%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)&X-Plex-Device=SHIELD%20Android%20TV&X-Plex-Platform=Android&X-Plex-Platform-Version=8.0.0&X-Plex-Product=Plex%20for%20Android&X-Plex-Supported-Commands=abort&X-Plex-Version=7.2.2.6114&X-Plex-Token=...atxz
07-31 02:38:04.392 i: [PlayQueueAPIHelperBase] Result container=
07-31 02:38:04.396 i: [MediaSessionHelper] Setting media session playback state with tag video and state 3
07-31 02:38:04.402 i: [MediaSessionHelper] Setting media session playback state with tag video and state 3
07-31 02:38:04.404 i: [MediaSessionHelper] Setting media session playback state with tag video and state 3
07-31 02:38:04.406 i: [MediaSessionHelper] Setting media session playback state with tag video and state 3
07-31 02:38:04.421 i: [MediaDecisionEngine] Server was happy with client’s original decision
07-31 02:38:04.422 i: [MediaDecisionEngine] Decision: CanPlay: true CanDirectPlay: true CanDirectStreamVideo: true CanDirectStreamAudio: true CanDirectPlaySubtitle: false CanTranscodeSubtitle: false
07-31 02:38:04.422 i: [FF] Releasing demuxer.
07-31 02:38:04.438 i: [video] Decision made, transcode: false
07-31 02:38:04.438 i: [TranscodeSession] Media choice updated
07-31 02:38:04.438 i: [VideoOverlay] Updating…
07-31 02:38:04.438 i: [video] Starting Playback for: Clash Of Kings
this is what it did this morning
sheilds log.2txt.txt (77.5 KB)
any one ? got any helpfull hints?
any one help here?
Ok i am at a loss
will swap out the year-old switch and swop the nic on the server, but after that, there is nothing left to swop and 2 different devices are on different AP points eliminating the wifi
(so the main question is why is emby not seeing the same thing, it on the same server, its streaming from the same device ?
thanks
mbu
ok swapped the nic on the server to a different nic and replaced the switch with a known good one
and still doing it
pretty sure this is not hardware related.
just started up plex again
here are the logs
Plex Media Server Logs_2018-08-03_16-55-42.zip (3.8 MB)
here is the logs after it has ran for a couple of min and a screen shot to confirm the abovePlex Media (3.5 MB)
nope - not on the server or the client
have set to secured preferred and that address is my amp(it does not stream to or from this device it is on the network for updates to the amp)
why is it adding a amp with dlna , when dlna is turned off?
any way here are the logs and it stopped at 1748 and Plex Media Server Logs_2018-08-03_17-54-08.zip (3.5 MB)
that might have been when i asked it to continue and it stalled so stopped it an dasked ot play again and played fine,
will play again and post when stops again without asking it to restart
ok 1815 stopped again
this time i did not ask it to play anything else
Plex Media Server Logs_2018-08-03_18-16-04.zip (3.6 MB)
this is windows 2016 server standard
reexported them again Plex Media Server Logs_2018-08-03_18-40-05.zip (4.7 MB)
the synology is a back up and stops via that server as well
but all the tests i have been playing with are via the primary (windows 2016 server)
