So I have been doing a little bit of experimenting around to narrow down what is causing my issues with plex connect. I am experiencing the DNS server not working after my router reboots, disconnects for a while w/e it also happens randomly with no router issues - the dns server just stops working. The http portion handles itself fine but the DNS Server doesn't like the change. Restarting plex connect works fine. Is there a way to fix this so the DNS Server restarts every x minutes or fixes itself when it detects network changes?
Have you got logs for when this occurs?
I have not seen this issue with a rougher reboot personally.
Here is the log file. It does this randomly and it is not always related to the router.
21:01:55 PlexConnect: started: 21:01:55
21:01:55 PlexConnect: Version: 0.5
21:01:55 PlexConnect: Python: 2.7.6 (default, Nov 10 2013, 19:24:24) [MSC v.1500 64 bit (AMD64)]
21:01:55 PlexConnect: Host OS: win32
21:01:55 PlexConnect: PILBackgrounds: Is PIL installed? False
21:01:55 PlexConnect: IP_self: 192.168.1.10
21:01:55 DNSServer: started: 21:01:55
21:01:55 DNSServer: ***
21:01:55 DNSServer: DNSServer: Serving DNS on 192.168.1.10 port 53.
21:01:55 WebServer: started: 21:01:55
21:01:55 WebServer: ***
21:01:55 WebServer: WebServer: Serving HTTP on 192.168.1.10 port 80.
21:01:55 WebServer: WebServer: Serving HTTPS on 192.168.1.10 port 443.
21:02:11 PlexAPI: ***
21:02:11 PlexAPI: looking up Plex Media Server
21:02:12 PlexAPI: GDM: Servers discovered: 1
21:02:12 PlexAPI: Servers (local+MyPlex): 1
21:42:07 DNSServer: Shutting down.
That log shows no traffic to Plexconnect so sorry can’t help, Need a log with Loglevel = High when the issue occurs.
I have bypassed my issue now. I am using DNSMasq on dd-wrt. No issues related to dns since i'm using this now. I have set the settings.cfg to disable the DNS Server now.
