Strange Plexamp Equalizer Issue
I’ve got a weird thing going on with Plexamp. Running it on macOS (10.15.7) or as an appimage in Linux (tried Arch and Debian), I’m only able to move the 50hz slider in the equalizer. If I grab any other slider, and try to drag it, only the 50hz slider moves. Graphic EQ’s in other apps work fine. Not sure what to look at or try. Anyone have any ideas?
try pushing/pulling the slider from below/above the dot.
SMACKS MY FOREHEAD
I can’t believe it was that simple LOL! Thank you!
I reported this a while back as did jmx.
That’s great to know that putting your cursor above or below the target point adjusts the EQ. I do hope this isn’t the intended operation and the bug has been registered to be resolved.
