UI issue
Sorry for spamming this thread. Got a bit of a problem with UI. Cast icon is getting in the way of the equalizer as below. Can’t adjust the 16khz bar. :confused:
Just moved from streaming and building my personal music collection again so new user.
Easy workaround… “pull” it down, you can drag starting below the actual dot. Alternatively you can tap the frequency band to zero it out.
That worked thanks. I was just tapping anyway along its length and it wasn’t responding. The tap and drag did the trick.
There’s plenty of real estate on the screen. Point forward to slightly adjust it below. He’ll, just make it much large for easier fine tuning. Great experience so far with Plexamp.
Absolutely agreed, moved it down a bit :sweat_smile:
