Stream suddenly stop on fire tv
Server Version#: 1.43.0.10346
Using XMLTV?: Yes
Hello,
since a week now i have issue with personnal live tv, the stream start correctly, sometimes buffering and can suddenly stop randomly…
Live tv seems stable on Samsung and roku
here’s the log from fire tv
Thanks!
11-26 09:30:56.786  i: [LoadControl] Setting buffer size to 73,19 MB / 0 seconds.
11-26 09:30:56.791  e: [ExoPlayer][EventLogger] playerFailed [eventTime=581.70, mediaPos=0.00, window=0, period=0, errorCode=ERROR_CODE_IO_UNSPECIFIED
  androidx.media3.exoplayer.ExoPlaybackException: Source error
      at androidx.media3.exoplayer.ExoPlayerImplInternal.handleIoException(SourceFile:16)
      at androidx.media3.exoplayer.ExoPlayerImplInternal.handleMessage(SourceFile:302)
      at android.os.Handler.dispatchMessage(Handler.java:102)
      at android.os.Looper.loop(Looper.java:223)
      at android.os.HandlerThread.run(HandlerThread.java:67)
  Caused by: androidx.media3.exoplayer.upstream.Loader$UnexpectedLoaderException: Unexpected NullPointerException: Attempt to invoke virtual method 'int com.plexapp.plex.net.w1.w0(java.lang.String)' on a null object reference
      at androidx.media3.exoplayer.upstream.Loader$LoadTask.handleMessage(SourceFile:147)
      at android.os.Handler.dispatchMessage(Handler.java:106)
      ... 2 more
  Caused by: java.lang.NullPointerException: Attempt to invoke virtual method 'int com.plexapp.plex.net.w1.w0(java.lang.String)' on a null object reference
      at nj.y.b(SourceFile:20)
      at nj.z.c(SourceFile:9)
      at nj.z.onLoadCompleted(SourceFile:2)
      at androidx.media3.exoplayer.upstream.Loader$LoadTask.handleMessage(SourceFile:131)
      ... 3 more
11-26 09:30:56.792  e: [Player][ExoPlayer] Playback error detected
11-26 09:30:56.793  e: An exception occurred: androidx.media3.exoplayer.ExoPlaybackException: Source error
11-26 09:30:56.794  e: Stacktrace: androidx.media3.exoplayer.ExoPlaybackException: Source error
	... 2 more
	... 3 more
11-26 09:30:56.795  i: [Player][Timeline] Handling player error
11-26 09:30:56.796  i: [Player][Timeline] Playback stopped (error: true)
11-26 09:30:56.796  w: [Player][Timeline] player position was negative. Position time will be reported as 0.
11-26 09:30:56.799  i: [ExoPlayer][EventLogger] state [eventTime=581.71, mediaPos=0.00, window=0, period=0, IDLE]
11-26 09:30:56.802  i: Fetching [method:GET] https://192.168.2.11:32400/:/timeline?airingID=434928&audioStreamID=1264889&context=dvrGuide%3Afb635b8ee22d4987650d9feca1bd5e34ab79523e&duration=601751&guid=tv.plex.xmltv%3A%2F%2Fepisode%2FLa%2520ru%25C3%25A9e%2520vers%2520l%2527or%253A%2520les%2520mines%2520perdues%2F2%2F1&key=%2Flivetv%2Fsessions%2F06124c63-b340-4d86-b335-bfb81af44f60&playbackTime=574699&playQueueItemID=30-1764165600000&ratingKey=398799&state=stopped&time=0&token=...oVA5&X-Plex-Client-Identifier=2cc577460ace2817-com-plexapp-android&X-Plex-Token=...oVA5&X-Plex-Language=fr-ca
11-26 09:30:56.814  i: [Player][Timeline] Player error not known by server, reporting original player error (or a playback interrupted one)
11-26 09:30:56.815  i: [Player] Error reported: UnknownError (null)
11-26 09:30:56.815  i: [TranscodeSession] Stopping...
11-26 09:30:56.816  i: [TranscodeSession] Session already stopped.
11-26 09:30:56.816  i: [Player][Timeline] Playback stopped (error: false)
11-26 09:30:56.817  w: [Player][Timeline] player position was negative. Position time will be reported as 0.
11-26 09:30:56.819  i: Fetching [method:GET] https://192.168.2.11:32400/:/timeline?airingID=434928&audioStreamID=1264889&context=dvrGuide%3Afb635b8ee22d4987650d9feca1bd5e34ab79523e&duration=601751&guid=tv.plex.xmltv%3A%2F%2Fepisode%2FLa%2520ru%25C3%25A9e%2520vers%2520l%2527or%253A%2520les%2520mines%2520perdues%2F2%2F1&key=%2Flivetv%2Fsessions%2F06124c63-b340-4d86-b335-bfb81af44f60&playbackTime=574718&playQueueItemID=30-1764165600000&ratingKey=398799&state=stopped&time=0&token=...oVA5&X-Plex-Client-Identifier=2cc577460ace2817-com-plexapp-android&X-Plex-Token=...oVA5&X-Plex-Language=fr-ca
11-26 09:30:56.831  i: [Player][Error] Displaying player error...
11-26 09:30:56.832  i: [DialogBehaviour] Showing dialog.
11-26 09:31:00.194  i: [LiveAiringMediaItemsMonitor] Something has started or ended. Calling listener
11-26 09:31:00.196  i: Fetching [method:GET] https://192.168.2.11:32400/tv.plex.providers.epg.xmltv:11/hubs/channels/recent?includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...oVA5&X-Plex-Language=fr-ca
11-26 09:31:00.260  i: [LiveAiringMediaItemsMonitor] Cancelling change detection
11-26 09:31:00.260  i: [LiveAiringMediaItemsMonitor]. Will signal items changed in 1800000 milliseconds
11-26 09:31:56.384  i: [FFmpeg] [INFO] [FFmpegExtractor] Demuxer context has already been closed.
11-26 09:31:56.385  i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been closed successfully.
11-26 09:31:56.385  i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been terminated successfully.
11-26 09:34:12.506  i: [HttpServer] /192.168.2.27:58294 - GET /favicon.ico
11-26 09:34:41.612  i: [HttpServer] /192.168.2.11:40459 - GET /logging
Plex Media Server Logs_2025-12-01_20-25-33.zip (5.6 MB)
Mines giving the exact same errors. However I’ve always had issues with livetv crashing out on the fire tv sticks, even before the 1.43 betas but definitely seems worse now. Strangely I have found 1 channel that this never occur on, BBC1 (I’m UK), and one channel that is worse than all the others, SKYMIX. It isn’t a server or dvr issue as all players other than android based ones work fine for all the channels.
I think the root cause of exoplayer bugging out on android is this line from the debug logs, it seems to be the first thing that occurs after what looks like usual stream requests:
androidx.media3.datasource.HttpDataSource$InvalidResponseCodeException: Response code: 416
So? Is there anyone to help?
