Streaming on Android using cellular not working
Server Version#: 1.28.0.5999
Player Version#: 9.6.0.34226
Android Version#: Oxygen OS 11.0.9.1 on OnePlus 7T
Works fine over WiFi locally and remotely but fails when using Android + cellular.
Also tested using iOS on iPad and it works seamlessly on cellular for the same server.
08-08 19:25:44.935  e: [PlexServerWebSocket] (ID: 9164652 | Server: Desktop) Connection failed.
08-08 19:25:44.936  e: An exception occurred: java.io.IOException: Unexpected response code for CONNECT: 403
08-08 19:25:44.936  e: Stacktrace: java.io.IOException: Unexpected response code for CONNECT: 403
	at okhttp3.internal.connection.RealConnection.createTunnel(SourceFile:17)
	at okhttp3.internal.connection.RealConnection.connectTunnel(SourceFile:4)
	at okhttp3.internal.connection.RealConnection.connect(SourceFile:14)
	at okhttp3.internal.connection.ExchangeFinder.findConnection(SourceFile:39)
	at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(SourceFile:1)
	at okhttp3.internal.connection.ExchangeFinder.find(SourceFile:7)
	at okhttp3.internal.connection.RealCall.initExchange$okhttp(SourceFile:8)
	at okhttp3.internal.connection.ConnectInterceptor.intercept(SourceFile:2)
	at okhttp3.internal.http.RealInterceptorChain.proceed(SourceFile:12)
	at okhttp3.internal.cache.CacheInterceptor.intercept(SourceFile:27)
	at okhttp3.internal.http.BridgeInterceptor.intercept(SourceFile:22)
	at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(SourceFile:7)
	at okhttp3.logging.HttpLoggingInterceptor.intercept(SourceFile:4)
	at com.plexapp.plex.net.s.intercept(SourceFile:36)
	at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(SourceFile:16)
	at okhttp3.internal.connection.RealCall$AsyncCall.run(SourceFile:6)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
	at java.lang.Thread.run(Thread.java:923)
08-08 19:25:44.989  e: Presenter not found! Type: unknown, Subtype: unknown
