Stuck in Playlists in music library
Plex/AndroidTV version: 7.8.0.11051
Platform: NVidia Shield
Steps:
  1. In UNO UI, go to a Music library for which there are no playlists.
  2. Change the view to Playlists.
At this point, it shows ‘No items to display.’ However, now I can’t change the View back to ‘Recommended’ or ‘Library.’ This library is stuck on an empty ‘Playlists’ page.
I have tried the following to get out of this state:
  1. Exit and restart the Plex app.
  2. Disable and re-enabled Uno experience.
  3. Unpin Library.
  4. Scan Library Files.
None of the above had any effect. My library is stuck.
I tried this in another Music Library that does have playlists, and this problem does not happen, so it appears to be tied to the lack of Playlists.
EDIT: Signing out and back in worked.
Hey!
Thanks for the report! This issue should be fixed in the next beta which will be released in a couple of days.
