stuck on accessing trailers
i don't know what happened.
and please don't lock this. you didn't understand what i was talking about. in one thread it was plex channels and in the other one the atv channels.
anyway, everything worked out great and now all the channels in the atv works like movies and youtube and all but trailers stuck on accessing trailers then trailers not availble
redownloaded and web server not alive ?:
sudo ./PlexConnect.py
Password:
23:22:33 PlexConnect: started: 23:22:33
23:22:33 PlexConnect: ***
23:22:33 PlexConnect: PlexConnect
23:22:33 PlexConnect: Press ENTER to shut down.
23:22:33 Settings: add section PlexConnect
23:22:33 Settings: add option port_pms=32400
23:22:33 Settings: add option enable_plexgdm=True
23:22:33 Settings: add option ip_dnsmaster=8.8.8.8
23:22:33 Settings: add option ip_webserver=0.0.0.0
23:22:33 Settings: add option loglevel=Normal
23:22:33 Settings: add option enable_dnsserver=True
23:22:33 Settings: add option ip_pms=192.168.178.10
23:22:33 Settings: add option port_webserver=80
23:22:33 PlexConnect: IP_self: 192.168.1.16
23:22:33 DNSServer: started: 23:22:33
23:22:33 DNSServer: ***
23:22:33 DNSServer: Starting up.
23:22:33 DNSServer: intercept trailers.apple.com: 192.168.1.16
23:22:33 DNSServer: forward other to higher level DNS: 8.8.8.8
23:22:33 WebServer: started: 23:22:33
23:22:33 WebServer: Failed to connect to HTTP on 0.0.0.0 port 80: [Errno 48] Address already in use
23:22:33 PlexConnect: WebServer not alive. Shutting down.
23:22:36 DNSServer: DNS request received!
23:22:36 DNSServer: Source: ('192.168.1.42', 63243)
23:22:36 DNSServer: Domain: a97.gi3.akamai.net
23:22:36 DNSServer: ***forward request
23:22:37 DNSServer: -> DNS response from higher level
23:22:37 DNSServer: Shutting down.
tomer:PlexConnect-XML_templates tomer_gold$
after redownloaded i went to settings.cfg and for the first time xcode told me i have no permissions to edit (wanted to change ip pms onto my ip, shouldn't i do that ?) and told me i don't own the file.
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):3
  • 5.3
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS):192.168.1.16
  • The device and operating system (including version number) that PlexConnect is installed on:imac os x 10.8.4
  • The local IP address of the device that PlexConnect is installed on:192.16.8.16
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on:imac os x 10.8.4
  • The Plex media server (PMS) version number you are running (**do not put 'latest'**):Version 0.9.7.28.33-f80a4a2
  • The local IP address of the device that the Plex media server (PMS) is installed on:192.168.1.16
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
  • redownloaded a few mins ago
  • The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
    [PlexConnect]
    port_pms = 32400
    enable_plexgdm = True
    ip_dnsmaster = 8.8.8.8
    ip_webserver = 0.0.0.0
    loglevel = Normal
    enable_dnsserver = True
    ip_pms = 192.168.178.10
    port_webserver = 80
  • please help !
checked what's using port 80. it doesn't mean anything to me, how about for you ?
sudo lsof -i -P
COMMAND    PID           USER   FD   TYPE             DEVICE SIZE/OFF   NODE NAME
launchd      1           root    9u  IPv6 0xb012a9f717770df1      0t0    TCP *:895 (LISTEN)
launchd      1           root   10u  IPv4 0xb012a9f717775dd9      0t0    TCP *:895 (LISTEN)
launchd      1           root   14u  IPv4 0xb012a9f717349ec9      0t0    UDP localhost:60762
launchd      1           root   24u  IPv4 0xb012a9f717349d41      0t0    UDP *:137
launchd      1           root   25u  IPv4 0xb012a9f717349bb9      0t0    UDP *:138
launchd      1           root   32u  IPv6 0xb012a9f717770631      0t0    TCP localhost:631 (LISTEN)
launchd      1           root   33u  IPv4 0xb012a9f717774f69      0t0    TCP localhost:631 (LISTEN)
UserEvent   11           root  134u  IPv4 0xb012a9f7173481b1      0t0    UDP *:*
syslogd     24           root   14u  IPv4 0xb012a9f718f9d931      0t0    UDP *:60359
mDNSRespo   36 _mdnsresponder    8u  IPv4 0xb012a9f7173498a9      0t0    UDP *:5353
mDNSRespo   36 _mdnsresponder    9u  IPv6 0xb012a9f717349721      0t0    UDP *:5353
mDNSRespo   36 _mdnsresponder   25u  IPv6 0xb012a9f717346499      0t0    UDP *:*
mDNSRespo   36 _mdnsresponder   27u  IPv6 0xb012a9f717345239      0t0    UDP *:*
mDNSRespo   36 _mdnsresponder   36u  IPv4 0xb012a9f71e862621      0t0    UDP *:54994
mDNSRespo   36 _mdnsresponder   38u  IPv4 0xb012a9f718fa0289      0t0    UDP all-systems.mcast.net:5350
mDNSRespo   36 _mdnsresponder   39u  IPv6 0xb012a9f718fa0721      0t0    UDP *:*
mDNSRespo   36 _mdnsresponder   41u  IPv6 0xb012a9f717348029      0t0    UDP *:54994
mDNSRespo   36 _mdnsresponder   42u  IPv4 0xb012a9f722371001      0t0    UDP *:60263
mDNSRespo   36 _mdnsresponder   43u  IPv6 0xb012a9f71e864339      0t0    UDP *:60263
mDNSRespo   36 _mdnsresponder   44u  IPv4 0xb012a9f722372ea1      0t0    UDP *:54586
mDNSRespo   36 _mdnsresponder   45u  IPv6 0xb012a9f71e864f79      0t0    UDP *:54586
mDNSRespo   36 _mdnsresponder   48u  IPv4 0xb012a9f722371499      0t0    UDP *:52804
mDNSRespo   36 _mdnsresponder   61u  IPv6 0xb012a9f71e862f51      0t0    UDP *:52804
mDNSRespo   36 _mdnsresponder   62u  IPv4 0xb012a9f722373649      0t0    UDP *:61323
mDNSRespo   36 _mdnsresponder   65u  IPv6 0xb012a9f718f9c0b1      0t0    UDP *:61323
mDNSRespo   36 _mdnsresponder   75u  IPv4 0xb012a9f718fa0d41      0t0    UDP *:51117
mDNSRespo   36 _mdnsresponder   76u  IPv6 0xb012a9f717346f51      0t0    UDP *:51117
mDNSRespo   36 _mdnsresponder   77u  IPv4 0xb012a9f71e863881      0t0    UDP *:62050
mDNSRespo   36 _mdnsresponder   78u  IPv6 0xb012a9f718f9ce79      0t0    UDP *:62050
mDNSRespo   36 _mdnsresponder   79u  IPv4 0xb012a9f71e861b69      0t0    UDP *:58421
mDNSRespo   36 _mdnsresponder   80u  IPv6 0xb012a9f722370859      0t0    UDP *:58421
mDNSRespo   36 _mdnsresponder   81u  IPv4 0xb012a9f71e865289      0t0    UDP *:59515
mDNSRespo   36 _mdnsresponder   82u  IPv6 0xb012a9f71e8658a9      0t0    UDP *:59515
mDNSRespo   36 _mdnsresponder   83u  IPv4 0xb012a9f71e862311      0t0    UDP *:49380
mDNSRespo   36 _mdnsresponder   84u  IPv6 0xb012a9f718fa0599      0t0    UDP *:49380
mDNSRespo   36 _mdnsresponder   85u  IPv4 0xb012a9f7223726f9      0t0    UDP *:58232
mDNSRespo   36 _mdnsresponder   86u  IPv6 0xb012a9f722373ae1      0t0    UDP *:58232
mDNSRespo   36 _mdnsresponder   94u  IPv4 0xb012a9f718f9d621      0t0    UDP *:58325
mDNSRespo   36 _mdnsresponder   97u  IPv6 0xb012a9f722374411      0t0    UDP *:58325
mDNSRespo   36 _mdnsresponder  100u  IPv4 0xb012a9f71e864029      0t0    UDP *:59428
mDNSRespo   36 _mdnsresponder  101u  IPv6 0xb012a9f718f9d499      0t0    UDP *:59428
mDNSRespo   36 _mdnsresponder  102u  IPv4 0xb012a9f71e861cf1      0t0    UDP *:53696
mDNSRespo   36 _mdnsresponder  103u  IPv6 0xb012a9f722371931      0t0    UDP *:53696
mDNSRespo   36 _mdnsresponder  104u  IPv4 0xb012a9f722370b69      0t0    UDP *:63165
mDNSRespo   36 _mdnsresponder  105u  IPv6 0xb012a9f718f9d189      0t0    UDP *:63165
locationd   40     _locationd    4u  IPv4 0xb012a9f7173467a9      0t0    UDP *:*
kdc         42           root    5u  IPv6 0xb012a9f7173484c1      0t0    UDP *:88
kdc         42           root    6u  IPv6 0xb012a9f717770251      0t0    TCP *:88 (LISTEN)
kdc         42           root    7u  IPv4 0xb012a9f717348339      0t0    UDP *:88
kdc         42           root    8u  IPv4 0xb012a9f717774831      0t0    TCP *:88 (LISTEN)
configd     53           root   11u  IPv6 0xb012a9f717349a31      0t0    UDP *:*
configd     53           root   19u  IPv4 0xb012a9f717349101      0t0    UDP *:*
configd     53           root   23u  IPv4 0xb012a9f717347571      0t0    UDP *:*
configd     53           root   25u  IPv4 0xb012a9f7173473e9      0t0    UDP *:*
configd     53           root   27u  IPv4 0xb012a9f717347261      0t0    UDP *:*
configd     53           root   30u  IPv6 0xb012a9f719513ec9      0t0 ICMPV6 *:*
blued       55           root    4u  IPv4 0xb012a9f717345cf1      0t0    UDP *:*
awacsd      56           root   11u  IPv6 0xb012a9f71a75d251      0t0    TCP [fd27:3b22:834f:b65e:1908:c426:7902:2a59]:4488 (LISTEN)
apsd        58           root    9u  IPv4 0xb012a9f731abb9c1      0t0    TCP 192.168.1.16:54068->17.149.34.59:5223 (ESTABLISHED)
apsd        58           root   10u  IPv4 0xb012a9f731ab45a9      0t0    TCP 192.168.1.16:54809->17.149.32.46:5223 (ESTABLISHED)
FlipShare   61           root   10u  IPv4 0xb012a9f71a74b289      0t0    TCP localhost:24726 (LISTEN)
FlipShare   61           root   11u  IPv4 0xb012a9f71a74ab51      0t0    TCP localhost:24727 (LISTEN)
netbiosd    94       _netbios    3u  IPv4 0xb012a9f717349bb9      0t0    UDP *:138
netbiosd    94       _netbios    4u  IPv4 0xb012a9f717349d41      0t0    UDP *:137
ntpd       103           root   20u  IPv4 0xb012a9f7173476f9      0t0    UDP *:123
ntpd       103           root   21u  IPv6 0xb012a9f7173470d9      0t0    UDP *:123
ntpd       103           root   22u  IPv6 0xb012a9f717346dc9      0t0    UDP localhost:123
ntpd       103           root   23u  IPv4 0xb012a9f717346c41      0t0    UDP localhost:123
ntpd       103           root   24u  IPv6 0xb012a9f717346ab9      0t0    UDP localhost:123
ntpd       103           root   25u  IPv6 0xb012a9f717346931      0t0    UDP tomer.local:123
ntpd       103           root   26u  IPv4 0xb012a9f71e865599      0t0    UDP 192.168.1.16:123
ntpd       103           root   28u  IPv6 0xb012a9f718f9fc69      0t0    UDP [fe80:8::1908:c426:7902:2a59]:123
ntpd       103           root   29u  IPv6 0xb012a9f717347b91      0t0    UDP [fd27:3b22:834f:b65e:1908:c426:7902:2a59]:123
cupsd      104           root   11u  IPv6 0xb012a9f717770631      0t0    TCP localhost:631 (LISTEN)
cupsd      104           root   12u  IPv4 0xb012a9f717774f69      0t0    TCP localhost:631 (LISTEN)
racoon     164           root    6u  IPv6 0xb012a9f718f9fae1      0t0    UDP [fe80:8::1908:c426:7902:2a59]:500
racoon     164           root    7u  IPv6 0xb012a9f718f9f959      0t0    UDP [fe80:8::1908:c426:7902:2a59]:4500
racoon     164           root    8u  IPv4 0xb012a9f71e863d19      0t0    UDP 192.168.1.16:500
racoon     164           root    9u  IPv4 0xb012a9f71e864c69      0t0    UDP 192.168.1.16:4500
racoon     164           root   10u  IPv6 0xb012a9f718f9f4c1      0t0    UDP tomer.local:500
racoon     164           root   11u  IPv6 0xb012a9f718f9f339      0t0    UDP tomer.local:4500
racoon     164           root   12u  IPv6 0xb012a9f718f9f1b1      0t0    UDP localhost:500
racoon     164           root   13u  IPv6 0xb012a9f718f9f029      0t0    UDP localhost:4500
racoon     164           root   14u  IPv4 0xb012a9f718f9eea1      0t0    UDP localhost:500
racoon     164           root   15u  IPv4 0xb012a9f718f9ed19      0t0    UDP localhost:4500
racoon     164           root   18u  IPv6 0xb012a9f718f9eb91      0t0    UDP localhost:500
racoon     164           root   19u  IPv6 0xb012a9f718f9ea09      0t0    UDP localhost:4500
racoon     164           root   20u  IPv6 0xb012a9f718fa0bb9      0t0    UDP [fd27:3b22:834f:b65e:1908:c426:7902:2a59]:500
racoon     164           root   21u  IPv6 0xb012a9f717348959      0t0    UDP [fd27:3b22:834f:b65e:1908:c426:7902:2a59]:4500
SystemUIS  210     tomer_gold    9u  IPv4 0xb012a9f717346621      0t0    UDP *:*
Finder     211     tomer_gold   16u  IPv4 0xb012a9f71a7a1ce1      0t0    TCP localhost:49231->localhost:26164 (ESTABLISHED)
NetworkBr  266     tomer_gold    5u  IPv4 0xb012a9f7173453c1      0t0    UDP *:*
Dropbox    289     tomer_gold   15u  IPv4 0xb012a9f731a3eb51      0t0    TCP 192.168.1.16:53285->108.160.163.49:80 (ESTABLISHED)
Dropbox    289     tomer_gold   21u  IPv4 0xb012a9f71a7a2419      0t0    TCP localhost:26164->localhost:49231 (ESTABLISHED)
Dropbox    289     tomer_gold   23u  IPv4 0xb012a9f717348df1      0t0    UDP *:17500
Dropbox    289     tomer_gold   26u  IPv4 0xb012a9f71a74c0f9      0t0    TCP *:17500 (LISTEN)
Dropbox    289     tomer_gold   33u  IPv4 0xb012a9f71a74d6a1      0t0    TCP localhost:26164 (LISTEN)
Skype      625     tomer_gold   12u  IPv4 0xb012a9f717349411      0t0    UDP localhost:51605
Skype      625     tomer_gold   15u  IPv4 0xb012a9f718f9e0d9      0t0    UDP *:*
Skype      625     tomer_gold   35u  IPv4 0xb012a9f731ad69c1      0t0    TCP 192.168.1.16:53310->db3msgr5011007.gateway.messenger.live.com:443 (ESTABLISHED)
Skype      625     tomer_gold   36u  IPv4 0xb012a9f731ac6289      0t0    TCP 192.168.1.16:53301->111.221.77.158:40031 (ESTABLISHED)
Skype      625     tomer_gold   56u  IPv4 0xb012a9f7319ce831      0t0    TCP 192.168.1.16:55354->193.120.199.16:12350 (ESTABLISHED)
Skype      625     tomer_gold   57u  IPv4 0xb012a9f71e2266a1      0t0    TCP *:29579 (LISTEN)
Skype      625     tomer_gold   58u  IPv4 0xb012a9f718f9c859      0t0    UDP *:29579
Skype      625     tomer_gold   62u  IPv4 0xb012a9f731a655a9      0t0    TCP 192.168.1.16:54009->dub402.hotmail.com:443 (ESTABLISHED)
Skype      625     tomer_gold   65u  IPv4 0xb012a9f731aa55a9      0t0    TCP 192.168.1.16:29579->178.53.49.185:41368 (ESTABLISHED)
Skype      625     tomer_gold   74u  IPv4 0xb012a9f731abc0f9      0t0    TCP 192.168.1.16:29579->host224-220-static.28-87-b.business.telecomitalia.it:51403 (ESTABLISHED)
Messages   628     tomer_gold   15u  IPv4 0xb012a9f73197c831      0t0    TCP *:* (CLOSED)
Messages   628     tomer_gold   16u  IPv4 0xb012a9f71e865a31      0t0    UDP 192.168.1.16:16402
WebProces 1152     tomer_gold   35u  IPv4 0xb012a9f7319bd6a1      0t0    TCP 192.168.1.16:53349->fxpimages.spd.co.il:8002 (ESTABLISHED)
WebProces 1152     tomer_gold   37u  IPv4 0xb012a9f731aedb51      0t0    TCP 192.168.1.16:55394->github.com:443 (ESTABLISHED)
WebProces 1152     tomer_gold   40u  IPv4 0xb012a9f731997ce1      0t0    TCP 192.168.1.16:55395->195.10.51.90:443 (ESTABLISHED)
WebProces 1152     tomer_gold   42u  IPv4 0xb012a9f7319ed419      0t0    TCP 192.168.1.16:55397->bud02s03-in-f30.1e100.net:443 (ESTABLISHED)
Python    1870           root    4u  IPv4 0xb012a9f72fc70ce1      0t0    TCP *:80 (LISTEN)
Python    1870           root   11u  IPv4 0xb012a9f731abf5a9      0t0    TCP 192.168.1.16:80->88.229.185.118.dynamic.ttnet.com.tr:62775 (ESTABLISHED)
BitTorren 2953     tomer_gold    7u  IPv4 0xb012a9f731a830f9      0t0    TCP *:26085 (LISTEN)
BitTorren 2953     tomer_gold    8u  IPv6 0xb012a9f71a75d631      0t0    TCP *:26085 (LISTEN)
BitTorren 2953     tomer_gold    9u  IPv4 0xb012a9f731b11831      0t0    TCP localhost:10000 (LISTEN)
BitTorren 2953     tomer_gold   10u  IPv4 0xb012a9f71fd52831      0t0    TCP 192.168.1.16:26085->cpe-75-83-34-66.socal.res.rr.com:54404 (ESTABLISHED)
BitTorren 2953     tomer_gold   11u  IPv4 0xb012a9f718fa0101      0t0    UDP *:26085
BitTorren 2953     tomer_gold   12u  IPv6 0xb012a9f722371311      0t0    UDP *:26085
BitTorren 2953     tomer_gold   13u  IPv4 0xb012a9f719513411      0t0   ICMP *:*
BitTorren 2953     tomer_gold   14u  IPv6 0xb012a9f719513599      0t0 ICMPV6 *:*
BitTorren 2953     tomer_gold   19u  IPv4 0xb012a9f718fa08a9      0t0    UDP localhost:54801
BitTorren 2953     tomer_gold   20u  IPv4 0xb012a9f722370cf1      0t0    UDP 192.168.1.16:55880
BitTorren 2953     tomer_gold   21u  IPv4 0xb012a9f71e864df1      0t0    UDP *:1900
BitTorren 2953     tomer_gold   37u  IPv4 0xb012a9f722373df1      0t0    UDP *:6771
System    3260     tomer_gold    8u  IPv4 0xb012a9f717346311      0t0    UDP *:*
System    3260     tomer_gold   34u  IPv4 0xb012a9f718f9ff79      0t0    UDP *:*
Plex\x20M 3447     tomer_gold   29u  IPv4 0xb012a9f731a52dd9      0t0    TCP *:32400 (LISTEN)
Plex\x20M 3447     tomer_gold   53u  IPv4 0xb012a9f722374101      0t0    UDP *:32414
Plex\x20M 3447     tomer_gold   58u  IPv4 0xb012a9f718fa0411      0t0    UDP *:32410
Plex\x20M 3447     tomer_gold   59u  IPv4 0xb012a9f7223717a9      0t0    UDP *:32413
Plex\x20M 3447     tomer_gold   60u  IPv4 0xb012a9f71e8636f9      0t0    UDP localhost:57886
Plex\x20M 3447     tomer_gold   61u  IPv4 0xb012a9f71e862931      0t0    UDP 192.168.1.16:49525
Plex\x20M 3447     tomer_gold   63u  IPv4 0xb012a9f71e8647d1      0t0    UDP localhost:63211
Plex\x20M 3447     tomer_gold   64u  IPv4 0xb012a9f71e863ea1      0t0    UDP 192.168.1.16:52929
Python    3448     tomer_gold   13u  IPv4 0xb012a9f731af3289      0t0    TCP *:55121 (LISTEN)
Plex\x20D 3449     tomer_gold   14u  IPv4 0xb012a9f71e8633e9      0t0    UDP *:1900
Plex\x20D 3449     tomer_gold   17u  IPv4 0xb012a9f731b57831      0t0    TCP *:1493 (LISTEN)
Plex\x20D 3449     tomer_gold   20u  IPv4 0xb012a9f730226c69      0t0    UDP *:11212
Plex\x20D 3449     tomer_gold   24u  IPv4 0xb012a9f71e863571      0t0    UDP *:12337
Plex\x20D 3449     tomer_gold   27u  IPv4 0xb012a9f718f9f7d1      0t0    UDP *:9462
Plex\x20D 3449     tomer_gold   30u  IPv4 0xb012a9f731b3a6a1      0t0    TCP *:32469 (LISTEN)
Plex\x20D 3449     tomer_gold   33u  IPv4 0xb012a9f71e865101      0t0    UDP *:56901
Plex\x20D 3449     tomer_gold   39u  IPv4 0xb012a9f731b3f289      0t0    TCP localhost:55122->localhost:55121 (CLOSE_WAIT)
Plex\x20D 3449     tomer_gold   40u  IPv4 0xb012a9f718f9cb69      0t0    UDP *:51699
Plex\x20D 3449     tomer_gold   44u  IPv4 0xb012a9f717347ea1      0t0    UDP 192.168.1.16:63242->192.168.1.1:5351
Plex\x20D 3449     tomer_gold   49u  IPv4 0xb012a9f71e863a09      0t0    UDP *:60898
Plex\x20D 3449     tomer_gold   53u  IPv4 0xb012a9f722374101      0t0    UDP *:32414
Plex\x20D 3449     tomer_gold   54u  IPv4 0xb012a9f731a790f9      0t0    TCP localhost:32400->localhost:55116 (TIME_WAIT)
Plex\x20D 3449     tomer_gold   55u  IPv4 0xb012a9f731ab7831      0t0    TCP localhost:32400->localhost:55117 (TIME_WAIT)
Plex\x20D 3449     tomer_gold   56u  IPv4 0xb012a9f731a1edd9      0t0    TCP localhost:32400->localhost:55119 (TIME_WAIT)
syncdefau 3480     tomer_gold   15u  IPv4 0xb012a9f731960ce1      0t0    TCP 192.168.1.16:55390->17.172.192.35:443 (ESTABLISHED)
syncdefau 3480     tomer_gold   16u  IPv4 0xb012a9f731a7e0f9      0t0    TCP 192.168.1.16:55391->17.172.192.35:443 (ESTABLISHED)
https://github.com/iBaa/PlexConnect/wiki/Port-80-already-in-use
Also try rebooting your mac.
Still some python scripts alive. Either PlexConnect didn't shutdown correctly before, or there is something else...
restarting did it ..
probably yea .. restart shutted them down right
