Hi all,
I am having trouble with stuttering HEVC Main 10 1080p 60fps video using the Plex app on my Roku stick. I would appreciate any help you can offer.
The HEVC sample linked at the bottom of this post demonstrates the issue on my Roku. File details:
Media
Duration 0:30
Bitrate 3256 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Video Resolution 1080p
Container MKV
Video Frame Rate NTSC
Audio Profile lc
Video Profile main 10
Part
Duration 0:30
File H265 Main10 4.1 (No tuning) CRF24 Med 1080-60p Remuxed 2.mkv
Size 11.66 MB
Audio Profile lc
Container MKV
Codec HEVC
Bitrate 3256 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Coded Height 1080
Coded Width 1920
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 29.97 fps
Height 1080
Level 4.1
Profile main 10
Ref Frames 1
Width 1920
Display Title 1080p (HEVC Main 10)
Codec AAC
Channels 2
Language Italiano
Profile lc
Sampling Rate 48000 Hz
Title AAC Stereo
Display Title Italiano (AAC Stereo)
Server Version#: 1.19.4.2935
Player Version#: 6.6.2.6457-57b807617
Client device: Roku Streaming Stick +
- I have made sure the app is using direct play.
- The client is connected to the network via Wifi (802.11n). Server is wired (1 GBe). Bandwidth doesn’t seem to be an issue.
- The sample plays fine on my phone using the Plex app for Android v7.30.0.16390 (5d527228).
- An H264 version, identical in every other respect, plays fine on the Roku.
(I previously posted about this here: HEVC Main 10 1080p Stuttering on Roku Ultra)
The video in question is 1080p 60fps HEVC Main10@4.1 (not HDR) encoded using Handbrake 1.3.1 (2020010400). The original was 60i interlaced blu-ray H264 8-bit - I chose to convert to 10-bit as I am finding from my tests that the extra color precision reduces blockiness/banding with minimal penalty in terms of performance or file size. Of course it needs to play properly on my devices which is obviously the catch!
Here are two samples - one HEVC with the problem described, the other H264 High@4.1 which works fine. I have updated the samples from my original post to remove all irrelevant tracks.
HEVC video sample (stutter) 12MB
H264 video sample (no stutter) 18MB
(Apologies for all the singing.)
It could be a Roku problem but I thought I would run it past the Plex community first.
Many thanks.
