Subtitle glitches
During Watch Together streams, subtitles fail to display. The subtitles UI itself becomes corrupted, reporting in different sections that the subtitles are alternately enabled or disabled.
When resuming a stream that had been playing via Watch Together, then subtitles spring up in duplicate, showing the same dialogue twice.
Which app were you casting from? Or were you using our Android TV app with the Chromecast/GoogleTV that has the remote?
What type of subtitles where they, SRT? Are they Embedded in file or external?
I want to try to reproduce
Not casting from any device. Using the Chromecast directly.
Subtitles selected using Plex’s subtitle lookup feature. Not embedded.
