Subtitle Offset not showing anymore
I can’t see the option for " Subtitle Offset" anymore on my smart tv and pc app.
It only works for external subs text based subs. If they are internal or something like a PGS then it will not show the option for that media file.
Plex Media Player is not supported https://support.plex.tv/articles/subtitle-offsets/
I was using my LG Smart TV and it didn’t work with srt subs. It used to work in the past, not only on the Smart TV but on the windows plex app.
Please copy the contents of the Plex XML info into here, taken from the affected video.
Should I just copy the XML web URL and paste here?
No, absolutely not!
Doping so will reveal your Token, which is as good as your username + password!
Copy the content of the XML file.
body limit is 40000…
It is safe to cut off the lower part with all the “related” movies.
or put in in a .txt file and upload the file
