Subtitle out of Sync and other questions
Hello!
I just got a raspberry pi for rasplex, and I'll be the first to admit I know very little of what I'm doing at this point and am a bit exhausted, so bear with me.  I've installed 0.1.37.
When playing media with subtitles, the subtitles seem out of sync.  Below you will find the media infor one of the files.  I was curious if there is anyway to change the subtitle offset to fix this issue?
EDIT: Figured out the remote.  Subtitles are still out of sync though.
Any help on any of this would be appreciated, for now, I may sleep.
Thanks!
MEDIA
  • Duration 24:29
  • Bitrate 3805 kbps
  • Width 1920
  • Height 1080
  • Aspect Ratio 1.78
  • Video Resolution 1080p
  • Container MKV
  • Video Frame Rate 24p
FILE
  • Accessible Yes
  • Exists Yes
  • Duration 24:29
  • File *:\Tv Shows\Fullmetal Alchemist Brotherhood\Fullmetal Alchemist Brotherhood S1E01.mkv
  • Size 666.72 MB
  • Container MKV
VIDEO
  • Codec H264
  • Bitrate 2450 kbps
  • CABAC 1
  • Duration 24:29
  • Frame Rate 23.976 fps
  • Height 1080
  • Level 4.0
  • Profile high
  • Ref Frames 3
  • Scantype progressive
  • Width 1920
AUDIO
  • Codec AC3
  • Channels 5.1
  • Bitrate 448 kbps
  • Language English
  • Bitrate Mode CBR
  • Dialog Norm -31 dB
  • Duration 24:29
  • Sampling Rate 48000 Hz
SUBTITLES
  • Language English
  • Format VOBSUB
AUDIO
  • Codec AC3
  • Channels Stereo
  • Bitrate 192 kbps
  • Language 日本語
  • Bitrate Mode CBR
  • Duration 24:29
AUDIO
  • Codec AC3
  • Channels Stereo
  • Bitrate 640 kbps
  • Language English
  • Bitrate Mode CBR
  • Duration 24:29
At least you have subtitles. I am struggling to get subtitles to appear on some of my animes.
Do the subtitles play in sync on your PC, for example? Or are they out of sync on any device?
The subtitles are in sync on any other plex client and if I play on my PC with VLC.
