Subtitles not playing automatically
Server Version#: 1.24.3.5033
Hello, I have configured languages as in the picture:
And the subtitles do not play automatically
firefox_fwGgnemhN4
I found something in the logs that might be relevant:
Sep 28, 2021 18:04:58.254 [8906] Debug — We’re going to try to auto-select an audio stream for account 1.
Sep 28, 2021 18:04:58.254 [8906] Debug — Selecting best audio stream for part ID 14923 (autoselect: 1 language: es)
Sep 28, 2021 18:04:58.254 [8906] Debug — Audio Stream: 37523, Subtitle Stream: 0
Which makes no sense… because the only language found is English…
If you select different languages for audio and subtitles, “shown with foreign audio” doesn’t work.
What could I do if I want to prioritize Spanish audio without subs but, in case there is no Spanish audio and there is English audio, put English audio with English subs?
Thank you for your response.
You cannot prefer two different audio languages.
If you select Spanish, you will get Spanish audio.
If the video has no Spanish audio, Plex will simply use the first audio track in the file – whichever language it is.
I understand this, and in the case that the audio is not in Spanish, I want English subs to be played automatically (99% of the movies I do not have in Spanish are in English).
I can not do this with the configuration showed in the images?
No, unfortunately you can only have Spanish subs played automatically.
The whole auto-selection only works as expected when the preferred languages for audio and subtitles are identical.
Ok, I understand it. Thanks for your help.
One last question about this. If selecting different languages for audio and subtitles doesn’t work, what is the sense in having an option to select the subs language?
