Subtitles, where do they go?
I have recently started a PlexPass subscripton and I found the ability to download subtitles from the server interface to be really helpful.
I didn’t see any subtitles saved in my media folders though so I was wondering, where are they saved, and do they disappear if my plexpass subscription lapses?
Server Version#:
They go into the Plex data folder. I think they don’t vanish after the Plex Pass lapses.
If you want access to them (for instance to refine their timing etc) I recommend you to use WebTools to download them.
OK, thanks :slight_smile:
