Suggested Collections improvements // mod-edit: options for automatic poster creation
I would like to make a few suggestions to improvements for the collection feature.
The collection feature is a very nice feature for users with a large library, but since it was introduced it havn’t gotten much love/updates.
So here is a few
  1. Sorting within a collection:
I would like to see more sorting options within a collect.
At the moment there is 3: Alphabetical, release date and custom/user defined (not sure what its called in the english version).
I would like to see more like:
higest rating
most recently added to the server
most recently added to the collection
Also the custom sorting it self could use some improvement in my opinion.
Its nice that you can just drag the titels around for sorting. But i have at least a few times seen this sorting get messed up. Im not sure if it happens doing server restart/plex service restart og doing server updates/plex server updates.
But i would like to see an option like “Sorting titel within this collection”-field on the individual titels.
Where it would simple be putting in 1, 2, 3, 4, and so on for manual sorting. And this way it should be saved and not messed up by a restart/updates.
[mod-edit: duplicate; see below]
  1. Add poster options.
Im not sure how the posters for the collections is created. But it doesn’t seem that well programmed. See screenshot:
2.1 As you can see from my “DC Universe”-collection, although it have 30 titels, The Superman-poster is used twice for some reason.
2.2 The “Eastrail 177 Trilogy”-collection have 3 titels, yet only 1 poster. While my “Has Fallen”-collection also have 3 titels and then it have all 3 posters while 1 is doubled ofcourse.
In generel this seems very random how these posters for collections is created/updated.
It would be nice to have an some options, while 1 of them is being default when a new collection is created.
Options like:
a. 4 random selections
b. First 4 titels in the collect is used (And this will ofcouse look at the sorting within the collect, alphabetical, realse date or how its sorted)
c. Last 4 titels in the collect is used
d. First titel + 2 random in the middle titels + last titel.
e. Manual select 4 posters in a view-menu of some sort
And then also an option to update/re-create a new collection poster based on current option. After you might have added more movies to a collection, it can update with those posters as well.
  1. Collection playback.
When i press play on a collection it will always start playing the first titel in that collection.
This should be like when you press play on a collection, it will start playing the next titel in the collection that is not “marked as seen”.
If i have a collection of 30 titels, and i’ve seen the first 20. I shouldn’t have to open the collection and then select the movie i want to watch. I should have a option to just click play and then the 21st titel starts playing.
And the same goes for a series library. I would to be able to just click play directly on the series or collection and then Plex plays the next unwatched titel/episode. [mod-edit: duplicate; see below]
There’s already a number of existing suggestions addressing those options.
*The OP is focusing on autoplay and continue watching (showing the next unwatched movie of a collection on the main page); the thread is however also discussing
I suggest you comment/vote in those threads in order to help us avoid distracting or cannibalizing votes.
I’m not sure about your second suggestion.
Most users I’ve seen prefer manually assigning a regular poster instead of the automatic poster collage.
As for the „Eastrail 177 Trilogy“… did you possibly set that poster?
I just went to look for my Eastrail 177 Trilogy to see what poster it got and it’s M.I.A.
Shouldn’t a minimum automatic collections size of 2 have created it?
I refreshed the metadata and the collection field for all 3 movies is still blank
Edit: Disregard
Apparently it’s no longer considered a collection :thinking:
You may want to consider letting Plex create those collections automatically so all the posters, backgrounds and descriptions are added
You may also want to check out the selection of posters here
6H42AxUhgcT83ahlmX7wj55OU6i3KQUrNXjaO43W
kSHvhQ6RpmNgEfYEUqmPHEZbwxz
A8fSV97FowDEwjrMqlhZWRAELipN38hfFfiRfe8v
uYqFB2Tp2P004J4WqFYQDCNe8KBTpwybbO1jQvlN
qm6JbrvRNL8HsXV1I6tZOFJjYe5
No, i havn’t set any manual posters in collections. I’m not sure how/when they are created.
I suspect that i added Split to the collection first. then it created the poster of just that 1 titel. Then when i added the 2 other titels i just didn’t update. I’m not sure.
Which is why i would like to set an option for this. Or at the very least an option to “update/create new poster”.
Plex doesn’t automatically make collections for me? Didn’t know this is a feature? I would guess that is turned off somewhere in my setting if there is such a feature.
That would be nice that it also adds descriptions as well as actually “collection-posters”, rather than just mixing up titel posters like i have.
3 dots next to the library → Manage Library → Edit → Advanced
Scroll down towards the bottom. Set the minimum size and save your changes
You may have to refresh the metadata for the library, I can’t remember if it does it automatically or not
All of the collections you showed will get made automatically so I would delete those beforehand except for the Eastrail 177 Trilogy.
Adding to the response provided by JaysPlex:
https://support.plex.tv/articles/201273953-collections/
Ah. Thats nice. Thanks for the tip.
Now i only have to make some minor adjustments for my needs.
