Server Version#:
I use plex app on my computer and want to control playback from mobile app but I am not able to do so. Also cast button doesnt show computer from mobile app.
Thanks a lot!!! Fixed.
Another question please.
I like the sound of plex apps. But as I see DSD files are sent to my DAC (musician pegasus) which supports dsd 512 at least, as 44 khz.
I’m afraid DSD is only supported by transcoding it to standard definition PCM.
The best you can do is to set your DAC to a high, fixed sample rate. Like 96 kHz, for instance. Then start Playback in Plexamp and everything will be upsampled to that.
