Switch to User - Im lost!
i activated my plex account in rasplex and after that rasplex showed me the interface to switch to another user. There is just one user.
The issue is, that I cannot control my rasplex anymore. I use the navigation on my iPhone to control rasplex, but the network navigation seems to be deactivated in this menu.
I can start a movie, but is is played in the background. I restared it several times, but rasplex always opens with this window.
Since I have no USB keyboard, I have no idea how to control rasplex :(
Have you tried with the TV remote ? (via CEC)
Until the iOS Plex App is updated you will not be able to control Rasplex 0.5.0, as suggested, use your TV remote, CEC is enabled by default, if you have switched it off you will need to re-enable it.
Regards
Thans Ned, CEC worked for me after renenabling it on my TV. It never worked before. I activated auto sign-in, so this wont be an issue anymore.
Since then, my iOS devices are working flawless with rpi and 0.5
Can you please mark this as answered, thanks.
